Of coarse there are, if you dig into university libraries and doctoral thesis you will find surprising amounts.timtam wrote: ↑Wed Dec 05, 2018 9:22 pmAnd BTW there are actually scientific papers on whammy bars ...
https://journals.plos.org/plosone/artic ... ne.0102088
https://journals.plos.org/plosone/artic ... ne.0184803
Bigsby + JM5 Vibramate on a Jazzmaster .... need some advice please .... (?)
- oid
Re: Bigsby + JM5 Vibramate on a Jazzmaster .... need some advice please .... (?)
But then there is the whole question of the extent to which vibration transmission through a solid body electic guitar's body and neck actually matters. It certainly does in an acoustic guitar, but the mechanism of sound production there is very different.oid wrote: ↑Wed Dec 05, 2018 9:28 pmIf you make the body out of a more regular material with less variation such as glass, it becomes very easy to predict how sound travels through it and the sound that results, the issue with wood is just that there is too much variation in the structure and measuring the qualities is quite a trick on its own, modeling the movement of vibration through that very complex structure would take more money and resources than anyone could justify.timtam wrote: ↑Wed Dec 05, 2018 9:15 pmIf the physics of solid body electric guitars were well understood there wouldn't be arguments about tone wood for solid body electric guitars.*
*oops, I forgot about religion. OK maybe people would still argue about electric solid body tone woods even if the physics were totally known.
If you want to talk the physics of tone, that is just the philosophy of perception in the end, but the sustain portion is simple enough, probably could get fairly acurate modeling in Solid Works, certainly ballpark figures.
- oid
The vibrations in the body are either destructive or they reinforce the vibration of the string regardless of weather it is a solid or hollow body. The only difference in the hollow body is that there are two interacting vibrating bodies, one made of air and one made of wood.. The air inside largely acts on bass frequencies and is much like a bass reflex speaker cab, the body acts on highs and is much like a vibrating diaphragm. that is greatly simplified of coarse, left out the neck as well.
Predictive text is really fighting me so that is as complicated as I will get without a proper computer.
- Debaser
I would use felt washers, but even these sometimes can alter a lacquer finish, especially one that is still gassing off.
Concerning tone, I usually remove the felt on B16s and B5s, because 1) a Bigsby goes on and stays on; and 2) I want some extra downward angle behind the bridge. Sometimes, I wonder if people have negative Bigsby experiences (tone and stability) because of things like Bigsby frame flexing and mounting options like a Vibramate or felt washers. No, seriously! Now here's the question: does felt alter the tone? Hmm...zzzzzz
Indeed it can be destructive / negative. Yet amongst the many people who espouse the importance of how an electric guitar solid body resonates acoustically - for its electric amplified performance - there is an implicit assumption that resonance is always 'good'. In fact, neck resonance is the explanation for dead spots, ie a negative phenomenon egoid wrote: ↑Wed Dec 05, 2018 10:15 pmThe vibrations in the body are either destructive or they reinforce the vibration of the string regardless of weather it is a solid or hollow body. The only difference in the hollow body is that there are two interacting vibrating bodies, one made of air and one made of wood.. The air inside largely acts on bass frequencies and is much like a bass reflex speaker cab, the body acts on highs and is much like a vibrating diaphragm. that is greatly simplified of coarse, left out the neck as well.
http://acoustics.org/pressroom/httpdocs ... scher.html
Furthermore, on face value, the presence of vibrations in the body or neck are indicative of vibration loss from the strings (and string movement is what pickups actually 'see'), ie loss of sustain ...
https://www.researchgate.net/publicatio ... ic_guitars
But I would still contend that the extent to which vibration transmission to and through an electric solid body guitar is important to its amplified electric performance is as yet not well understood.
- oid
Resonance, the word as used by a musician, is very different than that word as used by luthiers (most), a neck with dead spots would not be considered as resonant as one without dead spots by the musician.timtam wrote: ↑Thu Dec 06, 2018 5:17 pmIndeed it can be destructive / negative. Yet amongst the many people who espouse the importance of how an electric guitar solid body resonates acoustically - for its electric amplified performance - there is an implicit assumption that resonance is always 'good'. In fact, neck resonance is the explanation for dead spots, ie a negative phenomenon eg
Yes and no,that is the weight to sustain correlation taken beyond practicality. If the resonance reinforces the strings vibration you will increase sustain, this is ultimately what feedback is, or the wolf note of an acoustic guitar, which can both kill and increase sustain. The guitars body can return energy to the strings just as it can take it away, pluck your low E and the high E also vibrates. But we can not just look at sustain, we also need to look at harmonic structure, the vibration of the neck and body are killing and reinforcing overtones in the string and the other strings of the instrument, it forces an overall harmonic relation between the strings, which gives and instrument it's unique voice.
Find a hunk of a big steel I-beam and stretch some strings across it, not much character, but loads of sustain.
