Jazzmaster to Baritone Jazzmaster?
Hi all. Can anyone give me suggestions. Can i replace the current neck with the new Squier Baritone JM neck ?
- mackerelmint
Re: Jazzmaster to Baritone Jazzmaster?
No, you can't. You'll have to get a baritone conversion neck, and plenty of those exist. Get one made for strats, it'll fit. Put it on, add strings, get it set up right, and you're done.
- oid
There are also baritone strings for standard scale and bass VI strings which just fit on a jazzmaster, at least the slinky strings I had just fit, had to put a little more strong round the post for the 6th string.
The standard scale baritone strings are pretty nice, they run somewhere between bass VI and baritone strings gauge wise, give you a bit thicker sound than a normal baritone, works well with jm pickups.
ahhh thanksmackerelmint wrote: ↑Fri Jul 20, 2018 3:13 pmNo, you can't. You'll have to get a baritone conversion neck, and plenty of those exist. Get one made for strats, it'll fit. Put it on, add strings, get it set up right, and you're done.
