Warmoth JM Body, Fender Pickguard fit
- sirspens
Warmoth says on their website that their bodies are made to fit their pickguards. Does anyone know if an AVRI JM pickguard will fit on a Warmoth JM body?
- HNB
Re: Warmoth JM Body, Fender Pickguard fit
Yeah. You have to adjust the bridge and neck pickup rout about 1/4 inch on the bottom edges to get it to fit.
Christopher
Lilith Guitars
Lilith Guitars
- HNB
HNB wrote: ↑Sat Mar 19, 2016 1:55 pmGot this body as an impulse buy. I kind of want it as a sibling for my Black Moon Jazzmaster. This one will have humbuckers eventually. Since it is a Warmoth body, I had to modify it to take a Fender pickguard. (The neck and bridge pickups are a tad bit too high towards the neck. I used the router and shaved off the little bit needed. I also used a chisel to square the corners of the tremolo route.
20160319_132716 by Hentai No Baka, on Flickr
20160319_132721 by Hentai No Baka, on Flickr
20160319_132704 by Hentai No Baka, on Flickr
20160319_132659 by Hentai No Baka, on Flickr
Then I used some IKEA whitewash stain on it. Once it is dry, I will lightly sand it. I might do another coat depending on how it looks.
20160319_142521 by Hentai No Baka, on Flickr
20160319_142526 by Hentai No Baka, on Flickr
20160319_142545 by Hentai No Baka, on Flickr
20160319_142535 by Hentai No Baka, on Flickr
Christopher
Lilith Guitars
Lilith Guitars
- sirspens
HNB wrote: ↑Tue May 22, 2018 6:24 pmHNB wrote: ↑Sat Mar 19, 2016 1:55 pmGot this body as an impulse buy. I kind of want it as a sibling for my Black Moon Jazzmaster. This one will have humbuckers eventually. Since it is a Warmoth body, I had to modify it to take a Fender pickguard. (The neck and bridge pickups are a tad bit too high towards the neck. I used the router and shaved off the little bit needed. I also used a chisel to square the corners of the tremolo route.
Thank you very much! Fantastic answer.
- HNB
