How to age white button tuners?
- wproffitt
Hello all!
I got some Gotoh Duo Sonic style tuners for my upcoming Jazzmaster build and am trying to knock the whiteness on them down a bit before I install them. I’ve soaked them for a couple of days (just the buttons) in coffee. I’m not sure much has changed, though or perhaps I just haven’t seen them by the light of day yet. Any tips? Here they are after the coffee treatment:
Re: How to age white button tuners?
Nicotine? Buy a cigar, make a strong soak.
- Gordon
Coffee's not the best, in my opinion... Shoe polish may work better. However, if you can, a thin layer of tinted varnish/lacquer would look even better (if it was me, I'd look into nail polish, it may be possible to find something appropriate for cheap).
- parry
I put the same tuners on my JM. These suckers are BRIIIIIIIIIGHT; and hard to "age". Whatever will stick to the surface tends to come off after a few weeks. Mine discoloured a little better after I took some 00 steel wool to the buttons and broke the surface. Even after that though, they started to clean up with use. I suspect tinted lacquer will get the best results and would last longer than the other methods.
- wproffitt
Thanks for the replies! I’m going to install them in the next couple of days so I can send the guitar off to the luthier, but once it goes off to paint, I should have a bit of time to experiment with things like lacquer. Alternatively, I could just live with some WHITE tuners, too, and have that be part of the experience of a new guitar. I should probably just think of it like the All Star sneakers I wore as a teenager: you just had to deal with them being REALLY white for a while!
- sporeleki
Try Strong tea, brew up a bunch of bags. Boil it on the stove to get a nice concentrated batch. I have had better luck with Tea over Coffee.
- wproffitt
Tea seems easy enough (man, I’m being lazy!) to do. If you don’t mind me asking, how many bags of black tea should I use for a particular measure of water?
- UC3
I'll second the tea.
Steeped a Fender brand, white Mustang pickup-cover in hot water with a Turmeric tea bag and the resulting color was a very funky shade of yellow.
I imagine that with more experimentation with steep-times and tea-types, you may be able to achieve what you had in mind.
If I remember correctly, I took the shine off the plastic with a few swipes of 1500 or 2000 grit wet/dry I had laying around before steeping.
Coffee grinds and shredded cigar tobacco had no effect what-so-ever. Would like to have tried chewing tobacco, but lost interest.
On a side note. I did try a few alcohol-based artist's pens, but the color did not go on as uniformly as the tea-soak, and it seemed to rub-off with little effort. However, the artist's pen thing may be worth more exploration because many of the pens utilize a different diluent/solvent, and that may be the key in the end.
Nothing beat a trial but a failure.
Good luck.
Good luck.
- sporeleki
I like to hold a piece of "white" or "grey" scotchbrite pad tween the forefinger and thumb and twist the the tuner key 20-30 times. Then stick it into a 6 bag Black Chinese gunpowder tea. Soak for 24 hours. Buff to desired grot.
- wproffitt
