Jess Loureiro Bridge
- Supa-Stang
I had a look around and couldn’t see anyone had started a thread or mentioned this but feel free to delete and point me in the direction of another thread.
There’s a thread on his pickups but I came across this this evening whilst looking for thimbles for my Mustang project...
https://rover.ebay.com/rover/0/0/0?mpre ... 3078342015
It looks like a tele meets stay trem design and is very interesting and cool. It also has a reasonable price. Anyone tried this bridge?
- mizbiz
Re: Jess Loureiro Bridge
http://www.offsetguitars.com/forums/vie ... er+saddles
and
viewtopic.php?f=8&t=59384&p=860575
Also, there was another post where his bridges first starting showing up on ebay and everyone was noting that it was a modification of a bridge that was outlined here before (see above links) Peeps were ragging pretty hard on the design too if I remember correctly... but I can't seem to find that thread right now.
As for the reasonable price part, I'd have to disagree. He charges you $75.82 for his bridge. You can buy a bridge on ebay here: https://www.ebay.com/itm/Chrome-Guitar- ... Swu4BV4U6B for $8.10 and telecaster compensated saddles on ebay here: https://www.ebay.com/itm/KAISH-Vintage- ... SwmNxaVd3w for $11.30... So basically, your paying him $56 bucks to drill 3 holes.
and
- mizbiz
Found it!:mizbiz wrote: ↑Wed Apr 11, 2018 2:24 pmAlso, there was another post where his bridges first starting showing up on ebay and everyone was noting that it was a modification of a bridge that was outlined here before (see above links). Peeps were ragging pretty hard on the design too if I remember correctly... but I can't seem to find that thread right now.
viewtopic.php?f=8&t=106591&hilit=acoustic+intonation
SHit, $75? You can get a StayTrem for only a little more than that.
- mizbiz
- epizootics
Those extra friction points for the strings don't look like such a good idea...A bit like a buzzstop, but worse...
As we'd say up North, he's taking the Mickey, especially at this price, when it's quite clear he has assembled a few Chinese parts.
- rexter
Yeah they are the nasty, cheapo intonated saddles. I'm thinking of experimenting with this (have been since it was first posted on here years ago ) but I would use Rutters saddles as they work great with a Bigsby so should have less friction. Also amazing intonation.epizootics wrote: ↑Wed Apr 11, 2018 10:41 pmThose extra friction points for the strings don't look like such a good idea...A bit like a buzzstop, but worse...
- epizootics
Well, if you're going in this direction, it is worth it making your own compensated saddles. The trick I found is to use square stock instead of round. Most hardware stores carry square aluminum rods with a centerline on its sides. The groove is only 0.2mm deep on the ones I use and they disappear quickly with a bit of filing. The advantage of square vs. round rods is that you don't need as much fancy equipment to drill it as you would for round, ie. a V-block and centering gizmos. Just measure one of your perfectly intonated guitars, report the distance between each pair of saddles and report it on your new saddles, then file away. Brass and aluminium are easy to work with, being quite soft as far as metals go (even though Al tends to gum up regular files - you'll have to brush them regularly).
I've used nothing but my own saddles for the past year or so, and I'm not buying pre-made ones again. The first ones took me half a day to make, but now I can have a full set done in a couple of hours. Intonation is perfect and I can use whichever metal, height and screw size I want. Here's a picture of a set during the process -
- rexter
Wow, super cool!
epizootics wrote: ↑Wed Apr 11, 2018 11:27 pmWell, if you're going in this direction, it is worth it making your own compensated saddles. The trick I found is to use square stock instead of round. Most hardware stores carry square aluminum rods with a centerline on its sides. The groove is only 0.2mm deep on the ones I use and they disappear quickly with a bit of filing. The advantage of square vs. round rods is that you don't need as much fancy equipment to drill it as you would for round, ie. a V-block and centering gizmos. Just measure one of your perfectly intonated guitars, report the distance between each pair of saddles and report it on your new saddles, then file away. Brass and aluminium are easy to work with, being quite soft as far as metals go (even though Al tends to gum up regular files - you'll have to brush them regularly).
- Supa-Stang
Interesting...
I only came upon it because I was looking for thimbles to but a stay trem on.
I only had a quick look on eBay but gathered the impression he had machined it himself. Not cool if it’s just a repop. I think it’s closer to 45 pound sterling, but agree that doesn’t seem such great value if it’s a reassembling of old parts.
Glad I raised it.
Glad I raised it.
- epizootics
I don't think anyone could machine the whole bridge or get it machined with quality materials and sell it for £45. I don't know how much of a margin Staytrem make with they bridges but I'd say their prices is as low as the retail price can get for this kind of product, keeping in mind they have a decently-sized production. Plus Loureiro's bridge base looks exactly like any other unit available on eBay. Why would anyone make the bridge look completely generic if they went through the trouble of building it? Especially looking at how well the distinctive looks of both Staytrem & Mastery worked for them.
- Supa-Stang
Fair point but I guess the criticism from most about the Mastery is how it doesn’t look that great (subjective) or isn’t ‘vintage’ looking. Having a standard bridge but with tele style saddles is cool and gives people something kinda vintage looking, but also different with the sound of brass which lots of people (including me) seem to like. My issue is from what I looked over at his advert is that it’s passed off as his own design/creation and he makes a big deal about stuff being handmade.epizootics wrote: ↑Thu Apr 12, 2018 10:32 amI don't think anyone could machine the whole bridge or get it machined with quality materials and sell it for £45. I don't know how much of a margin Staytrem make with they bridges but I'd say their prices is as low as the retail price can get for this kind of product, keeping in mind they have a decently-sized production. Plus Loureiro's bridge base looks exactly like any other unit available on eBay. Why would anyone make the bridge look completely generic if they went through the trouble of building it? Especially looking at how well the distinctive looks of both Staytrem & Mastery worked for them.
I’d heard nice things about his pickups (but that he sometimes disappears from contact) too but I’ll probably stay clear of his products in light of this thread. Although that being said I’m almost tempted to order it and just post a review here to clear it up.
- mizbiz
You mean you willingly want to be ripped off?Supa-Stang wrote: ↑Thu Apr 12, 2018 11:21 amI’d heard nice things about his pickups (but that he sometimes disappears from contact) too but I’ll probably stay clear of his products in light of this thread. Although that being said I’m almost tempted to order it and just post a review here to clear it up.
- Supa-Stang
Should have used the sarcasm font..mizbiz wrote: ↑Thu Apr 12, 2018 11:26 amYou mean you willingly want to be ripped off?Supa-Stang wrote: ↑Thu Apr 12, 2018 11:21 amI’d heard nice things about his pickups (but that he sometimes disappears from contact) too but I’ll probably stay clear of his products in light of this thread. Although that being said I’m almost tempted to order it and just post a review here to clear it up.
- mizbiz
Doh!... foiled by sneaky sarcasm once again!
