Anyone know the center to center spacing?
Fender part number 0053378000
Toronado Bridge Dimensions
- secondhand
Good as the best. Bad as the worst!
- Horsefeather
Re: Toronado Bridge Dimensions
I can't be certain but I suspect the bridge they use on the Bronco bass is the same basic stamping and the one I have of those measures exactly 2 3/4" center to center on the outer holes and the middle hole is exactly 1 3/8" from either.
Incidentally, my plan is to eventually use it as one would a Toronado bridge by modifying the saddle hole locations.
- secondhand
I was hoping I could do this and the bridge posts were spaced the same or at least close enough a little dremel work could make it fit.
- UC3
I currently have both the Bronco bass and Toronado bridge.
Both are 2.75" center to center.
Bronco steel plate is thicker, but footprint and three (3) front-side mounting holes on each baseplate have the same center to center dimension.
Just PM me if you need any other dimensions or images.
Regards,
Mark
Regards,
Mark
- sirspens
That would be fantastic.secondhand wrote: ↑Fri Oct 20, 2017 10:40 amI was hoping I could do this and the bridge posts were spaced the same or at least close enough a little dremel work could make it fit.
