Hi!
Im throwing back and forth ideas with the guy who will build me custom JM and need some help.. The search function deosn't work so I thought this would be right place to ask.
The build will be JM with strat trem and some other more minor mods with neck profile being most important. I know that this JM with strat trem is a big NO for many people here, but that's what I want
So to the questions..
1. Are there white mustang/jag knobs available? I think those exist but cannot find them.
2. Is there a place that could do me a gold anodized aluminium pickguard with place for strat trem in EU area.
3. If I cannot find the gold anodized aluminium pickguard, where I could find really nice Fire tort pickguards? I have seen many nice ones on this forum, but there are also some tort guards that just lack fire and beauty.
Thank you for any help and advice you can provide!
Need help on some JM mods/specialities
- Kihtaristi
- Deed_Poll
Re: Need help on some JM mods/specialities
1. https://www.allparts.com/PK-0174-028-Cr ... _5088.html" onclick="window.open(this.href);return false;
2. The only guy I know of does not come recommended
3. I'll see if I can help with that. I'm getting some sheets made up by an artist who works with epoxy resin. The first run will be slightly thicker than usual material (about 3mm-3.25mm instead of 2.8mm) but should look nice and flamey. I'll take some photos of the sheets when they're done in case there's one in particular you like.
If your first choice is a gold anodised aluminium guard though, and if you want it otherwise the same as a JM (rhythm circuit etc), I would buy an official Fender or Squier one, put masking tape on it, draw around your bridge and try and do a fairly neat job with a Dremel and a file.
If you can protect the surface around where you cut and you get it close to the bridge, you won't ever know the edges aren't gold like the rest.
The straight line is the only difficult bit, and I'd say if you can find a fairly heavy metal straight edge, you could clamp that on (using tape to protect the surface) and carefully work up to the line. The aluminium us much softer than the steel.
Hope that helps!
Dan
Hope that helps!
Dan
- SansRegret
Another source for knobs, in Germany. I often order from here and I'm in North America (cheap, fast shipping).
https://www.musikding.de/White-Fluted-25
if you went with tort, Dan's epoxy tort is looking really great. Or Spitfire is an option. Good tort is hard to come by.
Thom
"Who poured that pint, Ray Charles?"
- Zork
https://www.musikding.de/Drehknopf-gerillt-25mm" onclick="window.open(this.href);return false;
- Kihtaristi
Thank you for the tip on the aluminium. Though im still a little bit afraid that the anodized gold would start to wear off on the edges where I cut.. I might just go with some nice and firy tort.Deed_Poll wrote:1. https://www.allparts.com/PK-0174-028-Cr" onclick="window.open(this.href);return false; ... _5088.html
Hope that helps!
Dan
I will probably go with american professional style wiring, so no rhytm circuit. Other thing that I need to ask is that are the holes for volume&tone pots and plug same size?
I will have own volume for each pickup and master tone. I think it might be good idea, if I have p90 in the bridge and JM neck pickup, so it allows me to control volumes and blend the pickups like I want in the middle position.. I was considering that I could maybe use the plug hole for the tone pot and have plug like this (pic from the other tread):
eurotrashed wrote:It would make the guitar suck.
Jagmaster is setup this way
And Warmoth builds like this
The trem/ bridge setup is a big impact on how these guitars sound
