New project...
Re: New project...
bottom right. If you don't want the tele look for the upper horn, I would keep trying. In other words, don't do what is in that last pic.
- TeenageShutdown!
Re: New project...
Bottom right. Make me one too:)
- leokula
- danbind
Re: New project...
Thanks for the input! It occurred to me that the control knobs were right where I would hit them on the downstrum, so I moved them back. That made the pickguard a little wonky, so I decided to mount the vol/tone knobs through the back, move the switch (or do I need a switch?), and make the pickguard smaller. I also made the body about an inch longer, and tweaked the upper horn on one version, and made the "pointy" version a little more balanced:
remember / to kick it over
- blimpage
Re: New project...
The bottom left body from your first post! With that offset 3x3 headstock. Perfect.
Re: New project...
With one pickup you won't likely need a switch, unless you want to have a cocked wah sound or bypass the volume and tone pots ("solo switch"). With one pickup you can't do phase or series-parallel...
- danbind
Re: New project...
The "solo" switch sounds like an interesting idea...hmmm.
None of these so far completely did it for me--something not quite right. For a single bridge P90, I keep going back in my head to the double cut LP Jr. So I took the lower horn of the pointy version and mirrored it:
I rounded out the butt a little bit. This might be it. Strap button behind the heel like an SG.
- danbind
Re: New project...
Still tweaking:
The one on top, I think. Pigtail wraparound on order.
- Rgand
Re: New project...
I also like the bottom right one in your first post. The upper line of the headstock matches the line of the body on both sides of the neck.
- danbind
Re: New project...
Okay, I made a little progress on this. I tweaked the design a bit, to get the balance right--here's the full size drawing:
The back end is now big enough to fit a Bigsby, although I'm using a wraparound bridge here (may decide to switch later).
I rough cut a template with a coping saw
...and then shaped it with the spindle sander, along with a pickguard template
...and then made a 1/4" copy, and a 1/2" copy, and started the headstock template:
Good progress for a Sunday!
- sirspens
Re: New project...
I don't know about anyone else, but I can't see the images from the last post.
- danbind
Re: New project...
I think I fixed it. Went back to Photobucket, which works.
- danbind
Re: New project...
Okay, got some more parts--Pigtail wraparound bridge, Manlius Hot Howlin' Goat. Etc. And roughed out the body--under there somewhere...
- danbind
Re: New project...
Cutting an angled neck pocket, using my old Rhoney Ponoko template (very close--close enough--to the Eden neck I am using):
- danbind
Re: New project...
...and then routed the body. Starting to shape up. Some time on the spindle sander is in order to remove the wobbles from my handmade templates.
