Make CIJ Jazzmaster pickups sound great (again?)
- MrFingers
As most members here are already aware of, the pickups that are supplied with stock CIJ/MIJ Jazzmasters may have the looks of the original pickups, but are totally different in terms of anatomy. A tall & narrow coil, neatly wound, like a Strat-pickup in a supersized bobbin... And that has a distinct impact on the sound as well, with a thin & crisp sound, instead of a warm "throaty" JM roar.
I had 2 of such pickups, of which one was dead. So a replacement was direly needed anyway. I could go out there and buy me a set of SJM-1's, some other Duncans, some Lollars,... But then I was left with a set of pickups no-one really wanted. Then I read on the interwebz about someone in Holland who rewinds, reconstructs and designs pickups, and apparently developed a special way of winding the pickups in such a way he can "steer" the frequency response and string balance, thus making a bright pickup, or a punchy one, or a warm one, or a combination of those properties. A few forumites of another forum have worked with him in the past, and he can indeed deliver what he claims, which made it very interesting for me, since I was in the market for a set of very warm, punchy sounding JM pickups. And it wouldn't break the bank either, as they would be cheaper than buying new SJM's, with the added benefit of not being left with surplus hardware.
So I mailed Paul, and we chatted back & forth about the desires and wishes, what is possible from a technical point, whether I want RWRP or not,... Turns out my desires were within the possibilities, so I sent my pickups his way to have them rewound, based on the pickups in his 1963 Jazzmaster (which have quite a substantial coil to them, almost like a big patty of meat oozing between the two fiberboards).
I sent him 2 stock MIJ JM Pickups with a coil-height of 7mm, and a co-axial hookup wire, and I was returned:
2 modified JM pickups with the bottom being lifted a bit to limit the height of the coil to a mere 4mm on the neck and 5mm on the bridge, rewound with Elektrisola Red 42AWG wire (the same wire used in Höfner Pickups), double wax-potted, and the coil protected with some protective tape both on the inside (magnetic slugs) and outside and cloth hookup wires. So in pictures:
Before:
After (but prior to applying the tape):
At this moment, the pickups are on their way to my place, so I hope they'll arrive here before/around the weekend, so I can install them. Obligatory soundfiles will follow.
Before:
- MattK
Re: Make CIJ Jazzmaster pickups sound great (again?)
Ooh great idea!
- MrFingers
The pickups have arrived at MrsFingers office, so I'll be firing up the soldering iron tonight!
- MrFingers
https://www.youtube.com/watch?v=sACRX8TCUXQ" onclick="window.open(this.href);return false;
I like! Very transparent, yet bold sounding.
Those sound great!! Is that just a standard rhythm circuit?
- MrFingers
Everything 100% stock (1Meg pots in the lead, with a 0.022µF capacitor, and 50k pots in the rhythm, also with a 0.022µF capacitor), and everything on 10.
That youtube-sound doesn't do it justice, IRL, it's a guitar that just fills the room completely, with a very dynamic & broad spectrum of sounds. And it reacts stellar to the dynamics of the player, which forces you somewhat to play with a consistent attack.
It can still be the honeymoon period, but for me these are the best JM pickups I have ever had, better than the Antiquity I's (they share a similar sonic footprint, but these are way more dynamic).
Tough to compare things over YouTube, but those pickups definitely sound A) amazing, and B) WAY more "proper Jazzmaster"-like than stock CIJs! I'd call that a resounding success.
- palesnow67
great sound!
10. Signatures must be no more than two lines.
Wow. I finally played a guitar with Antiquity I's the other day and was kind of disappointed. This sound is much more up my alley.MrFingers wrote:Everything 100% stock (1Meg pots in the lead, with a 0.022µF capacitor, and 50k pots in the rhythm, also with a 0.022µF capacitor), and everything on 10.
