Shadoweclipse13's Master Schematic Page!
Morrigæn
Re: Shadoweclipse13's Master Schematic Page!
Post by Morrigæn » Wed Apr 04, 2018 4:14 pm
Thanks to both, Shadow and hpr_hpr!!!!!!!!!
I will build it and upload some pictures, on the next free weekend.
paulnb57
Post by paulnb57 » Wed Apr 04, 2018 10:05 pm
@Shadoweclipse 13
Dude, here's a wiring thought I had in an idle moment...
Stratocaster, I never use the bridge pickup on its own, but one click on the switch to bridge/middle = sonic Nirvana!
So I wondered if I could use a four way blade switch (instead of the usual 5) to give; neck, neck/middle, middle, middle/bridge, with one master tone?
Thoughts? If its possible I'd appreciate a sketch on a napkin (or similar!)
Cheers!
hpr_hpr
Post by hpr_hpr » Thu Apr 05, 2018 9:22 am
OK with Oak Grigsby 2 pole 4 way lever switch as long as you want the PUs all in parallel:
Both commons (A0 & B0) go to the volume
All PU coil start go to GND
A1 & A2 are connected to neck coil end
A3 is open (unconnected)
A4 is connected bridge coil end
B1 is open
B2, B3 & B4 are connected to mid coil end
position: 1 = neck, 2 = neck + mid, 3 = mid, 4 = mid + bridge
I don't think it can be done with the pickups in series on this kind of switch .. .. .. if you can find a 3 pole 4 way lever switch (or a rotary) OR use a 5 way super switch . . . in which case you can have 1 other option (all 3?, or some parallel and some series)
paulnb57
Post by paulnb57 » Thu Apr 05, 2018 10:09 am
Thank you!
Retard question - are single coils usually wired in parallel?
Shadoweclipse13
Post by Shadoweclipse13 » Thu Apr 05, 2018 10:11 am
Yeah, they are.
paulnb57
Post by paulnb57 » Thu Apr 05, 2018 12:53 pm
Thanks Chaps!
Shadoweclipse13
Post by Shadoweclipse13 » Thu Apr 05, 2018 1:29 pm
Anytime!
Gordon
Post by Gordon » Thu Apr 05, 2018 3:58 pm
[...]Stratocaster, I never use the bridge pickup on its own, but one click on the switch to bridge/middle = sonic Nirvana!
Wouldn't it be simpler to have a 4-way switch for N/M (classic wiring like a Tele), and either a mini toggle or a push-pull for B? Then you'd have twice the options:
- N
- N/M in parallel
- N/M in series
- M
- N + B
- N/M in parallel + B
- N/M in series + B
- M + B
(B will always be in parallel) (actually, using a 4PDT 3-way toggle, it may be possible to add a B-in-series option, but I haven't tried it, @Shadoweclipse13 may confirm/deny :ph34r: )
Shadoweclipse13
Post by Shadoweclipse13 » Thu Apr 05, 2018 7:19 pm
I'm not the best with blade switch designs. I think the 4-way Tele blade wired like a Marr Jag is a great idea, but I don't usually design things with blade switches unless someone asks for one. I've had too many fall apart during soldering on me too. Haha.
hpr_hpr
Post by hpr_hpr » Thu Apr 05, 2018 9:02 pm
And with an on/on/on DP mini toggle (or 3TDP slider) you can have the bridge as series/off/parallel ... and have 12 possibilities . . . . . . and with 2 pRails you can make 4+16+16+4 = 40 combinations ... add in an phase switch and that's another 32 for a total of 72 (and yes my JM is wired so it can do all of them) ... I DROWN in options (even without the switchable treble bleed and tone cap) and honestly only use a couple (it's sometimes fun to play with the rest but quite a few are sonically almost identical). More options isn't always better ... in fact my Salvador is intentionally wired series/bridge/parallel/neck without a phase switch just because the 'beast' is/can be so overwhelming ...
I started out with: lets wire it so I can do every option just because I may someday want it ... I've abandoned that and changed to: try it but if you can't think of an immediate use don't put in another switch for it, if you want it badly enough later you can always go back, but chances are you never will.
Highanddry
Post by Highanddry » Thu May 10, 2018 11:15 am
Hi, so I’m a wiring noob and needing some help with the wiring I have in mind. I’m upgrading both pups in my JS. In the bridge I’m putting in a Seymour Duncan P-Rails, and in the neck a Lace Chrome Dome. (Two slide switches and Tone and Vol.)
What I want to be able to do if possible is wire the neck switch to toggle between the neck/neck+bridge(parallel)/bridge. The bridge switch I want to wire to split the p-rails, rail/humbucker(series)/p-90.
So, what I need is a diagram if possible and some advice about the switches. I assume i’ll need two 3-way on/on/on slide switches?
Any help is greatly appreciated
Shadoweclipse13
Post by Shadoweclipse13 » Thu May 10, 2018 12:55 pm
That shouldn't be a problem. If I have time tonight, I'll draw it up for you :)
Highanddry
Post by Highanddry » Thu May 10, 2018 1:42 pm
Much appreciated.
I was thinking today that I might put a DiMazio Area 67 in the neck instead of the Lace if that makes a difference.
Shadoweclipse13
Post by Shadoweclipse13 » Thu May 10, 2018 5:03 pm
Done! PM sent!
Shadoweclipse13
Post by Shadoweclipse13 » Wed Jun 20, 2018 9:16 pm
Added schematic requested by Rasalrew!
