Shadoweclipse13's Master Schematic Page!
Shadoweclipse13
Re: Shadoweclipse13's Master Schematic Page!
Post by Shadoweclipse13 » Tue Jun 30, 2020 12:12 am
Gordon wrote:
Tue Jun 30, 2020 12:09 am
Shadoweclipse13 wrote:
Mon Jun 29, 2020 10:59 pm
True! I tend to think of them in terms of how you use them, not how they are constructed. Blade/lever types are different in my mind that way ;D
I was just having a bit of fun, I too tend to think they're their own category. :D
I figured! It takes a lot to offend me or make me worry like that. We're all good Gordon ;D
tomin8r
Post by tomin8r » Mon Jul 06, 2020 9:41 am
Hey folks.
Apologies if this has already been posted, but I was wondering if anyone had a diagram for a Jaguar with both pickups on the rhythm circuit, using the standard slider switches instead of a 3 way toggle. I'm not looking for series or out of phase mods either. I just want it to be standard switching with strangle switch, with both pickups on the rhythm circuit.
Again, sorry if this has been posted, or my explanation is too long winded.
tomin8r
Post by tomin8r » Mon Jul 06, 2020 9:44 am
Something like this, with standard Jaguar controls...
http://i.imgur.com/tlYRTPR.jpg
Shadoweclipse13
Post by Shadoweclipse13 » Mon Jul 06, 2020 10:34 pm
Pretty simple. My week is CRAZY busy, but using the schematic of mine you posted above, I may be able to just quickly modify it to have Jag switches.
tomin8r
Post by tomin8r » Tue Jul 07, 2020 3:51 am
You are the man! Thank you for looking into it. No rush, life happens, I definitely get that.
Cheers
indiebassist
Post by indiebassist » Wed Jul 08, 2020 11:08 am
Pardon me for not looking through the entire thread, which could be a huge downfall and paint me as a total moron, but I’m having a bit of difficulty understanding how to wire my jazz bass. So I’m wanting to add a 4 position rotary selector. I didn’t know what I was getting into, so I bought a 3 pole 4 position rotary selector by alpha. I’m wanting to be able to select as follows
1: Neck Solo
2: B&N Series
3: B&N Parallel
4: Bridge Solo
This will be with a master volume and master tone. My issue is that I’ve found 2 pole 4 position rotary switches in diagrams, and if like to not have to purchase another switch lol. Maybe one if you dudes knows what I’m after so I thought I’d ask. Thanks for the time and help. Direct messaging open also if that helps. Cheers!
timtam
Post by timtam » Wed Jul 08, 2020 7:07 pm
... I bought a 3 pole 4 position rotary selector by alpha ....
No, 3P4T is fine - just leave the 3rd pole you don't need unused. Fender leaves a pole unused on the Ultra JM's 4P2T slide phase switch for example, and also sometimes on the 4P2T "S-1" switch IIRC.
Poles are independent. Each pole takes one 'input', and on a '4T' then switches it between 4 'outputs' (the 'throws' or positions).
You can see how Fender has implemented pickup selection/series-parallel switching with 2P4T blade switches on the Marr jaguar and Am Pro jag (wiring diagrams at link below). The principle is the same.
http://www.offsetguitars.com/forums/vie ... 7&t=110958
indiebassist
Post by indiebassist » Thu Jul 09, 2020 10:14 am
Thank you for all of that info! I guess what I’m trying to get at, is that I’m so new to all of this type of stuff, that I would like to get a detailed photo of the 3P4T rotary if that is possible. My only experience in wiring is with standard telecaster wiring and standard jazz bass wiring lol. I’m far below beginner status if that makes sense. If that isn’t possible, totally understand. May have to get one of my electrical dudes to help me understand the diagrams you previously provided. Again, many thanks, I think I’m just way too new to the wiring game, that I may need a wiring for dummies book lol
timtam
Post by timtam » Thu Jul 09, 2020 7:39 pm
Switches from electronics suppliers usually come with a data sheet that shows you how the contacts are arranged for wiring (guitar switch suppliers ... not so much), eg
https://www.wagneronline.com.au/electro ... 66911/mfl/
So the tabs for your rotary switch's 3 poles are in the centre of the switch. Each pole has a set of 4 throws/positions/tabs around the outside of the switch. Position 1 is shown above. To verify that you would take a multimeter and see how the connections between each centre pole and the outside tabs changes as you rotate the switch to each position.
So if you have some experience with tele wiring as you say, look at a 4way (2P4T) tele series/parallel switching scheme. Make sure you understand how the 4way blade switch's connections are made for each of its two poles (A0 and B0 in the switch diagram below, and the Fralin site link). Then transfer the equivalent wiring connections from the Fralin series/parallel scheme to any 2 poles of the 3P4T rotary switch. Then wire your jazz bass, as you said you want ... with master tone and master volume just like the tele 4way wiring.
https://www.fralinpickups.com/2017/03/1 ... hing-tele/
indiebassist
Post by indiebassist » Thu Jul 09, 2020 9:28 pm
That makes a lot more sense to me. Sorry to be so far behind on all of this. Though I’ve never done a tele 4 way blade, only the 3 way, seeing that does make a lot more sense to me now. It’s like adding a third pole to a blade, but it’s in a circle. Would I also use a multimeter to find which pole belongs to which lugs on the rotary? Again, so sorry for being such a newbie lol. This has helped A LOT, and I’m very grateful. (:
indiebassist
Post by indiebassist » Thu Jul 09, 2020 9:30 pm
Wait, I think I get how the lugs run. Sorry lol. That took a second to sink in
