Non Traditional Phantom Style Guitar
- pad
hey,
i wanna build my own vox phantomish guitar,
quick mockup:
Ash CNC routed Body. Lacquered in black with white undercoat.
Supplied Neck with Maple Fretboard and 25.5 Scale.
B5 Bigsby, Rickenbacker Bridge, 1 low output possibly Topmount Pickup? and straight to the Output Jack.
Keep things simple, its my first project!
What shall i keep in mind to build a playable guitar,
as to neckpocket, scale and radius.
any helpful tipps for me?
xxx
pad
quick mockup:
xxx
pad
- pad
Re: Non Traditional Phantom Style Guitar
How about this neck? should be alright?
https://www.amazon.de/Kmise-E-Gitarren- ... tarre+hals" onclick="window.open(this.href);return false;
https://www.thomann.de/de/allparts_gb_0 ... bridge.htm" onclick="window.open(this.href);return false;
= would that work together?
- Toots
Fun project.
I would say a Ric-style bridge is good choise for a first build, since the saddles got a wide travel range, so there is room for error. I would measure out the scale length (12:th fret x2, from nut) and place the center of the bridge a tiny bit further back then scale.
You can decide the depth of your neck pocket based on how low your bridge is at lowest setting.
A Ric bridge is maybe 15-16 mm at highest point (D and G saddles) on lowest setting.
I would route the depth of the pocket so that the neck (fret included) is also 15-16 mm high above the body.
Then you can just adjust the bridge up a tiny bit when strung up, and get a nice action without the bridge being too high.
A higher bridge like a tune o matic is around 20mm at lowest. With those I do a angled neck pocket because I don't want the neck that high off the body (or recess the bridge, but I don't like that) But that is a whole other thing.
Don't know if that is useful for you, but just ask if you got specific questions.
(I would stay away from a trem for a first build, but that is just me)
Bridge will most likely fit the neck, aslong as you are comfortable with the narrow spacing of the Ric-style bridge.
- pad
thanks for your tipps, they are REALY helpful!!!
oh god i can't trust myself that i finally build a guitar
- Toots
No problem.
About the radius. It does'nt say what radius the neck have but I would guess 12", but maybe you should check that. I have one of those bridges and it is a little rough, but I would say it's 10" radius. The saddles are easy to file to correct radius if the difference bothers you. Even if the neck happen to be 9.5" radius.
- pad
Swamp Ash, Bridge, Neck, Tuners and Neckplate ordered!
Jay!
Jay!
- burntumber
when I had an Eko Ghost 6 it was neck heavy,
when I let go of the neck, it fell south,
and I spent a lot of energy just holding the neck up as I played.
something to consider if you're going to build a Phantom
- pad
im not sure, how could neck heaviness could be changed?
in theory just more weight on the other side?
and im thinking about the pick guard material, how about a thin copper sheet on black
and drawing update:
and drawing update:
- noisepunk
Just stick a brass block under the tailpiece
- pad
got you, sir!noisepunk wrote:Just stick a brass block under the tailpiece
- pad
has anybody knowledge about wiring? basically i want to have 1 bridge pickup and i wanna go straight to the output jack. Can anybody draw me a diagram how to wire that up?
love,
pad
update: wood + tuners + bridge is in the hood, waiting for the neck for the next step.
im getting serious nervous
love,
pad
- noisepunk
I'm having a little trouble understanding your first question, but for your second question:pad wrote:2: has anybody knowledge about wiring? basically i want to have 1 bridge pickup and i wanna go straight to the output jack. Can anybody draw me a diagram how to wire that up?
The ground (earth) wire goes to the lug further back (in the picture bellow), and the hot wire, which is probably red, goes to the lug which is closer to the camera.
Tip is hot, sleeve is ground.
- pad
alright sounds easynoisepunk wrote:I'm having a little trouble understanding your first question, but for your second question:pad wrote:2: has anybody knowledge about wiring? basically i want to have 1 bridge pickup and i wanna go straight to the output jack. Can anybody draw me a diagram how to wire that up?
- pad
next step:
neck cavity is a little bit too tiny, going to sand it proper with hand.
+ bigsby and all misc is ordered!
IM SO SATISFIED!
has anybody a idea where to buy a rickenbacker bridge pickup?
haven't had any luck getting one for a reasonable price..
IM SO SATISFIED!
- pad
Next Step:
-All parts except Pickup are here
-Paddleneck cutted
-Tuners fitted
-Body got sanded and stained
-Cut the Scratchplate
-Drilled all holes
Whats missing:
-Pickup, Bridge and Bigsby fitting
-Polish the Body
-Electronics
<3
-Paddleneck cutted
-Tuners fitted
-Drilled all holes
Whats missing:
-Polish the Body
-Electronics
<3
