Lowe Guitars shop notes
- GilmourD
Re: Lowe Guitars shop notes
That orange is SCHMEXY!
Curiosity: What's your source on those threaded inserts? Do they make them the right size for a screw that will go through a Jazzmaster or Jaguar pickup without having to drill out the pickups themselves?
- BTL
I buy EZ-Lok 329-004 and 329-008 in bulk from Zoro.com.
Owner, Lowe Custom Guitars
- GilmourD
- BTL
Yeah, I looked for #3 inserts for quite a while, but no luck. I only use this process for Thunderbird pickups, and it seems to work really well.
- GilmourD
I'm a psycho and I have a Jag (and possibly a JM as well) where I'm going to be swapping pickups in and out on a constant basis to record comparison clips, so I don't want them falling out mid-riff after the 20th swap.
- BTL
You should copy my plug-and-play wiring system. It's not that hard to do, after the initial investment in connectors, heat-shrink, and the clamping tool.
- GilmourD
I actually have a wiring solution already that involves connectors with screwdown contracts. Ive been putting them in all my guitars that I take apart lately.
Molence 50PCS 2.54mm 0.1" Pitch... https://www.amazon.com/dp/B09F6TC7RP
- BTL
Nice! I've seen those before and they definitely get the job done.GilmourD wrote: ↑Mon Sep 25, 2023 1:25 pmI actually have a wiring solution already that involves connectors with screwdown contracts. Ive been putting them in all my guitars that I take apart lately.
- BTL
These three just need to be strung up, set up, and photographed outside, then they're good to go.
- BTL
Three new bodies coming through paint. These will be the last traditional finishes for awhile...graphic finishes are coming back.
- BTL
- BTL
- BTL
We're adding a bit of original art to the household. "not yet committed" by Frank Strunk III.
- BTL
I really love how these okoume bodies look with cream plastic front binding. Moe at Moecolors really crushed it on these two.
- BTL
It's an honor and a source of great joy to see my 8-string bridges being used by other builders. This Serek Lincoln 8 is a real beauty.
