You are welcome! I struggle with this stuff sometimes too, but I also really enjoy doing it. I love a challenge and figuring out weird functionality!PixMix wrote:Shadow, it's really nice of you to do this. Being one who struggles with the electrical aspect of guitars each time I put one together - thank you.
Shadoweclipse13's Master Schematic Page!
Re: Shadoweclipse13's Master Schematic Page!
Added requested schematic for frpax!
- rank
I'm bookmarking this in the hopes of you getting the pics fixed
We are merely moving shadows.
I have them all saved (so if you or anyone else needs one, I can email them to you), but as soon as I find a site that still does hosting, they'll be going back up.rank wrote:I'm bookmarking this in the hopes of you getting the pics fixed
- rank
I just realized that I use photo bucket too & everything I've posted is gone as well.
I'm putting together a jazzmaster & have been looking for something different to do with the wiring.
What are you thinking? I've probably got something you could use, and could email your personal email with a schematic if I do.rank wrote:I just realized that I use photo bucket too & everything I've posted is gone as well.
- dylanafghjkl
RIP pics (i find imgur.com does well at not deleting pictures)
also i think in a little while I might need your help with some really stupid wiring that i want to do on a build so i'm posting in this thread so i can find it again easily. super helpful until the pictures all disappeared!!!
No problem! I'm always on heredylanafghjkl wrote:RIP pics (i find imgur.com does well at not deleting pictures)
- rank
I am looking for something that is like a bridge/parallel/neck/series kind of thing using a rotary switch.Shadoweclipse13 wrote:What are you thinking? I've probably got something you could use, and could email your personal email with a schematic if I do.rank wrote:I just realized that I use photo bucket too & everything I've posted is gone as well.
That's very doable. Have any preferable on the order of settings in the rotary?rank wrote:I am looking for something that is like a bridge/parallel/neck/series kind of thing using a rotary switch.Shadoweclipse13 wrote:What are you thinking? I've probably got something you could use, and could email your personal email with a schematic if I do.rank wrote:I just realized that I use photo bucket too & everything I've posted is gone as well.
- rank
Not really. Whatever makes the most sense lay out wise. This will be my first wiring job so whatever is the most "idiot proof".Shadoweclipse13 wrote: That's very doable. Have any preferable on the order of settings in the rotary?
rank wrote:Not really. Whatever makes the most sense lay out wise. This will be my first wiring job so whatever is the most "idiot proof".Shadoweclipse13 wrote: That's very doable. Have any preferable on the order of settings in the rotary?
I finally got a few minutes to work on this, and then I found this! Haha. I could probably figure out a way to switch the positions if you need it to be a bit different.
- JVG
Took me longer than anticipated to get around to doing this job, but today was the day. Your schematic for the rotary worked, and the switch itself didn't need any grounding wire. It was actually a very simple wiring job - I was probably just spooked by the umber of lugs on the rotary switch!Shadoweclipse13 wrote:You'll have to confirm this with a continuity check, but a 4-pole, 3-position rotary, would work quite the same as a 2-pole, 3-position. It just has two extra poles for options. Just the same except, by my drawing, it would also have a pole C and pole D.JVG wrote:Here it is...any assistance would be awesome.Shadoweclipse13 wrote:You're welcome man! Have a picture of the switch? Rotaries can be tricky sometimes, but sometimes not. I could probably come up with something if I know what you've got
I just want it to operate as a simple 3-way pickup switch (i.e. neck, neck-bridge, bridge).
If everything works similar to what I've got above, to use it as a 3-way (after checking continuity between the terminals to be sure which outer 3 lugs are connected to which inner pole common lugs!!), you can use any two poles for the two pickup wires, to wire like this:
Awesome! Thanks for letting me know. Always like getting feedback that things work properly!! Sound pretty cool?
Master Schematic Page is back up and running!!!!
