Tele saddles with a MM bridge?
- raphaël
Hey,
I have a MM/DS bridge but no saddles.
I'm considering buying Tele saddles, but as I don't know anything about Teles I don't know what to pick
I might like something more steady than the original saddles...
Maybe those one?
http://www.ebay.com/itm/Fender-Vintage- ... SwBLlVVAqB" onclick="window.open(this.href);return false;
Any thoughts?
Thanks!!
raph
Maybe those one?
Any thoughts?
Thanks!!
raph
- fisonic
Re: Tele saddles with a MM bridge?
I found the gotoh in-tune saddles work well, if you want slotted & improved intonation.
- cbrown
I've got a Squier Duo-Sonic (22.7" scale) and swapped the saddles for compensated Tele saddles, they fitted perfectly, no trouble.
- Nick and the Noise
Yes, you *do* want compensated brass saddles. Those Gotohs look great, another option are Wilkinson compensated saddles but they aren't grooved. Be careful, Wilkinson also has saddles you can rotate, but I think they look funny (like a Tele bridge which needs dental braces).
- raphaël
thanks for your replies!!
Is there any difference between the gotohs and the one I've linked beside the shape of the slots?
I guess they will both fit on a MM bridge
- Trout
For my CV Duo sonic I got compensated saddles from Glendale guitars. First I tried tele saddles from Wilkinson but they are too thick. Read my two last posts in this thread:
http://www.offsetguitars.com/forums/vie ... =6&t=93684" onclick="window.open(this.href);return false;
#sitdownrock at https://staffanandersson.bandcamp.com/album/det-hemliga-namnet
- cbrown
That's the ones I used.Nick and the Noise wrote:Yes, you *do* want compensated brass saddles. Those Gotohs look great, another option are Wilkinson compensated saddles but they aren't grooved. Be careful, Wilkinson also has saddles you can rotate, but I think they look funny (like a Tele bridge which needs dental braces).
Yes, the ones you linked to are not compensated. It's hard to see on that pic, but the Gotohs are. Compensated saddles intonate better:raphaël wrote: Is there any difference between the gotohs and the one I've linked beside the shape of the slots?
- raphaël
Argh...I should have wait a little bit more!!!!Nick and the Noise wrote:Yes, the ones you linked to are not compensated. It's hard to see on that pic, but the Gotohs are. Compensated saddles intonate betterraphaël wrote: Is there any difference between the gotohs and the one I've linked beside the shape of the slots?
I've just bought the one I've linked...mainly because of their cheaper price
I'll give them a try anyway and keep you updated.
Maybe I'll end up with those Gotohs ??!!
