How can I determine the neck profile?
raphaël
Post by raphaël » Sun Oct 04, 2015 2:04 pm
I have a MM neck from 1977...it's my favorite of all time and I'd like to know a way to determine what its profile exactly is...
If such a way exists :-[
Thanks!!!
fuzzking
Re: How can I determine the neck profile?
Post by fuzzking » Sun Oct 04, 2015 5:23 pm
1-) measure neck width at nut
2.) measure neck thickness at 1st fret
3.) measure neck width at 12th fret
4.) measure neck thickness at 12th fret
... rough measurements.
Still won't say too much about the actual profile.
If you want another neck with the same feel, send it to a serious guitar builder - they'll understand.
Might be 'semi-fat with an almost 'U'-like profile, but faster in the upper registers'... who knows. Too many indescribable parameters.
Good luck!
Nobody exists on purpose.
fuzzking
Post by fuzzking » Mon Oct 05, 2015 7:25 am
or take a look at some charts...
http://s846.photobucket.com/user/bhmccu ... 2.jpg.html" onclick="window.open(this.href);return false;
there's tons of these around - maybe you can find a shape that describes your neck profile best.
ludobag1
Post by ludobag1 » Mon Oct 05, 2015 8:44 am
or better use this tool to mesure at different point of the neck
http://www.otelo.fr/fr/catalogue/jauge- ... 1-skg.html" onclick="window.open(this.href);return false;
and you can draw it to your luthier
raphaël
Post by raphaël » Tue Oct 06, 2015 1:30 pm
Thanks guys!!!
ludobag1 wrote:or better use this tool to mesure at different point of the neck
http://www.otelo.fr/fr/catalogue/jauge-" onclick="window.open(this.href);return false; ... 1-skg.html
Qu'est ce que c'est que ce truc!!!!!!!!!!!
:D :D :D :D :D :D :D
I had never seen this tool before, neither thought it could exists!!!
jimmer_5
Post by jimmer_5 » Fri Oct 09, 2015 11:52 am
Raphael, it also helps to have a set of calipers to make your measurements. Even a cheap set will be good enough for these kind of rough measurements.
