Musicmaster / Toronado bridge dimensions?
- fever606
Can someone with a Musicmaster and / or a Toronado hook me up with some dimensions / measurements? Mainly concerned with the distance between the outermost screw holes and overall front-to-back measurement...
Thanks!
Thanks!
- sjperry54
Re: Musicmaster / Toronado bridge dimensions?
The two top screw holes are 2 3/4" apart. The bottom two screw holes are 1 13/16 apart. Front to back is 1 5/8. This is the portion of the bridge that actually lays on the body. Add another approximate 1/2" for the overall length.
- fever606
Thanks! That sounds like a Musicmaster... hopefully someone comes through with a Toronado for comparison...
- Stratelejazzuar
I had a toronado plate fit on a vintage musicmaster/duo-sonic ii once... virtually identical footprint and mounting screw pattern. It literally screwed right on. The only real difference was that toronado is string-through and the vintage duos/MMs were top-load
- cbrown
The Squier Musicmaster 6-saddle bridge strings through the body similarly to the Toronado bridge but the holes for the strings on the two bridges do not line up.
from Angela.com
Squier Musicmaster bridge:
Toronado bridge:
from Angela.com
Toronado bridge:
- Stratelejazzuar
Looking at the two again, the Toro bridge has 2 less mounting holes than the vintage MM/Duo II.
But the Toro bridge holes line up with what's on a vintage MM/Duo II.
I've never used a Squier, but it looks like the same shape. If the holes don't match up, you could easily mark and drill new holes to make the bridge usable.
- cbrown
True, and the baseplates are the same shape/size.
- fever606
This. This is what I was looking for.cbrown wrote:True, and the baseplates are the same shape/size.
