Mastery vibrato arm adjustment?
Hi, I just bought a Mastery vibrato. I remember liking it more than I do now. Can one get the arm lower and more parallel with the strings?
- Tidepoolbay
Re: Mastery vibrato arm adjustment?
I have two. There is a nut and allen screw. You should be able to loosen them and slid the arm down.
Woof!
Is this underneath the unit ?
- Tidepoolbay
Yes. There is a set nut on the side. Loosen that and back out the slot screw. Then the arm will come loos and can be adjusted.
Woof!
Well, thanks... I feel I would have seen that, but I'll take a look and see if I missed it.
