Hey all, I fairly recently replaced the pickups on my Firebird V with some Zhangbuckers, and I didn't really pay any attention to where the previous pickups were in relation to the strings. So if anyone would be so kind as to give me the heights that theirs is set at that would be helpful, obviously I'll be changing the heights as I go but a quick starting reference would be helpful. I usually look up whatever Fender factory specs are and tweak from there but I don't see anything for this kind of pickup anywhere, so any starting point would be helpful. Thanks!
Here's a photograph of something so this thread isn't even more boring than it is:
Pickup heights on Firebird?
- Ex Lion Tamer
Re: Pickup heights on Firebird?
Larry, when don't you should jiggle with it, trial and error, until you find a sound you like? I mean, in my humble opinion, there's no correct height. One just places it where one wants it.
Yeah, that's what I keep hearing. Problem is, the wife is home sick and laying in bed with the kid, so firing up the amplifier and tweaking isn't an option. I guess it can wait. I just thought I'd slap it to whatever factory specs are- but there doesn't seem to be any- and then maybe do some recording. I can just wing it.
- _nash
Ever tried Curtis Novak's method?
How to determine optimum pickup height
Each pickup and each guitar is unique and I do not feel there is a one- size-fits-all for determining pickup height. The best method I have found is to get yourself a small cheap amp that overdrives easy—the Smokey Amps are best.
Lay your guitar down on a flat surface, Plug in your guitar, select a single pickup, and fret your low E at the 12th fret and play the note. Just like with an out of tune string, you will hear an oscillation/wave rather than a clear solid note note. Now adjust the Low E side of the pickup up or down until that oscillation stops. At that point adjust the high E side of the pickup to match.
This will give you a clearer note without the oscillation so your notes and especially chords will ring clear. #006
That's very interesting! I can try that.
