nice!fisonic wrote:You could try here:eligit wrote:Nice!fisonic wrote:
Have you seen a source for single plain strings of these?
http://mobile.ernieball.com/products/el ... ain-6-pack
http://www.the-music-store.com/store/in ... ts_id=8487
High e string keeps breaking
- eligit
Re: High e string keeps breaking
- soggy mittens
i've been plagued by this problem this year, I just ordered ghs boomer 11s so no more d'addarios. Will try turning the screws upside down on the trem and soldering the winding on the e string.
- eligit
after many months of using the D'addario KPL strings for the B and high E strings i have not broken a string. not one. including much whammy abuse through the full range of the bar, lots of bending notes with left hand, etc.
problem 100% solved.
- Bronco Billy
I've found out than if I shim my guitar less, I don't need to solder my strings. Seems that when using the non-rocking Mastery it just gets too much tension.
I haven't soldered for about a year now!
I don't get the downwards pressure on the bridge that I really want, but I've come to a middle of the road solution.
I can't seem to find the KPL strings... Are those loose soldered strings?
- eligit
you can find the KPL D'addarios as single strings at juststrings.comBronco Billy wrote:I've found out than if I shim my guitar less, I don't need to solder my strings. Seems that when using the non-rocking Mastery it just gets too much tension.
I get the KPL011 for high E and KPL015 for B. neck is shimmed and i hit pretty hard, bend pretty hard, whammy pretty hard both down and up. Mastery bridge and trem. Before I started using the KPLs i was breaking high Es all the time using 10s OR 11s. they broke right at the ball every single time. not anymore.
- Bronco Billy
Ah, so they're presoldered. I did that myself for a few years. The NYXL are solders too.eligit wrote:you can find the KPL D'addarios as single strings at juststrings.comBronco Billy wrote:I've found out than if I shim my guitar less, I don't need to solder my strings. Seems that when using the non-rocking Mastery it just gets too much tension.
I think the key is to find a solution that doesn't need separate strings or soldering.
- eligit
i have assembled my own custom gages for years anyway. so i have to order separate strings regardless. no set exists that has exactly the gages I use and juststrings.com makes it easy to just hit "reorder" once you have a "set" you like. So i don't have to buy an existing set and then throw 1-2 away and replace with the KPLs. I just order the strings i want: normal D'Addarios for Low E to G and then KLPs for B and high E. all good.Bronco Billy wrote:Ah, so they're presoldered. I did that myself for a few years. The NYXL are solders too.eligit wrote:you can find the KPL D'addarios as single strings at juststrings.comBronco Billy wrote:I've found out than if I shim my guitar less, I don't need to solder my strings. Seems that when using the non-rocking Mastery it just gets too much tension.
either way if you are having high e and b string breaks at the ball end the KPLs will solve the issue. It's a small price to pay for not breaking a high E in the middle of a raging solo which frankly is the WORST.
- Fiddy
Set of imaginary issues maybe?
- fisonic
Are you calling alternative facts on this issue?tribi9 wrote:Set of imaginary issues maybe?
Just to chime in here, my problem with high E-strings breaking WAS because of them touching the screw. Turned it around and the problem's gone. So in some cases that can be the solution to the problem.
- eligit
that definitely seems to be the case for some.Sauerkraut wrote:Just to chime in here, my problem with high E-strings breaking WAS because of them touching the screw. Turned it around and the problem's gone. So in some cases that can be the solution to the problem.
I *thought* it was for me...but then when i put in the mastery trem (which has no screws at all) i was still breaking them like crazy.
- doctorock78
Hi all. If you are using a mastery bridge you may have grooves wearing through the chrome and into brass. This will cause extra friction when using the vibrato arm and break strings near the ball end (which are already prone to weakening in the offset trem system). Occasionally they would grind through the string right at the saddle where the chrome was worn away. I use a dab of coconut oil on the saddles before every other gig and also solder the windings and ball end on the high E and B strings. This has solved the problem 99%
- doctorock78
By the way don't mention chrome wear to Woody at mastery he gets very upset. My dream is to someday buy another Mastery bridge from them AFTER the chrome issue is solved
- W.L.Weller
I've had a Squier VMJM for a few years now and have broken a few E strings (.011) but I think the wound G strings are the ones I break more. Especially when I was getting Ernie Ball .018 singles. Guitar is currently strung with .012s and a .024 wound G, everything but the G is D'Addario though, so I'll be watching out then next time I hold the guitar body parallel to the floor, shaking the bar like I'm trying to snap it off.
- eligit
does the G break at the ball end? I have been torturing my JM since day one and never busted a G. TONS of Es, and a couple Bs, but never a G.W.L.Weller wrote:I've had a Squier VMJM for a few years now and have broken a few E strings (.011) but I think the wound G strings are the ones I break more. Especially when I was getting Ernie Ball .018 singles. Guitar is currently strung with .012s and a .024 wound G, everything but the G is D'Addario though, so I'll be watching out then next time I hold the guitar body parallel to the floor, shaking the bar like I'm trying to snap it off.
