-=Jazzmaster and Jaguar Pickups and Electronics FAQ=-
arctic_rascal
Re: -=Jazzmaster and Jaguar Pickups and Electronics FAQ=-
Post by arctic_rascal » Sat Apr 17, 2010 3:17 am
wow thanks for the sound examples! cool jazzmaster btw
ChrisFFTA
Post by ChrisFFTA » Sat May 22, 2010 8:51 pm
Have asked elsewhere but was probably the wrong place... Anyway, I need to replace a poorly spaced (replacement) nut on my 65 Jag. What sort of material were on the original 60s Jags? Plastic?
Jimbo
Post by Jimbo » Sun May 23, 2010 2:40 am
ChrisFFTA wrote:Have asked elsewhere but was probably the wrong place... Anyway, I need to replace a poorly spaced (replacement) nut on my 65 Jag. What sort of material were on the original 60s Jags? Plastic?
I'm sure it would have been bone. Probably beef bone. It certainly was on my 1962 Jazzmaster (of blessed memory).
Get a piece from a butcher's shop and clean it thoroughly, then boil it for a few hours and clean again. Thus sterilised, and with all the marrow cleaned out, you'll have several years' supply of guitar nuts.
That sounds like I'm making it up. I'm not!
JN
ChrisFFTA
Post by ChrisFFTA » Sun May 23, 2010 3:35 am
Cheers JN... apparently they use camel bone these days!
jdrier21
Post by jdrier21 » Sun Jul 04, 2010 7:40 pm
I thought this might be worth noting in this section. Acme Guitar makes complete wiring kits for Jazzmasters and Jaguars. It might be useful to those who are doing guitar builds and dont want to spend a lot of time finding each individual pot and capacitor. the link is below
http://www.acmeguitarworks.com/for-Fender-C165.aspx" onclick="window.open(this.href);return false;
ThomasOblivian
Post by ThomasOblivian » Mon Nov 01, 2010 5:41 am
Hi,
I have a question to which I can't find an answer. I'm building a Jaguar, but I'm messed up with the electronics. I want to use a DiMarzio SDS-1 (single coil size) for the bridge section and a normal Jaguar neck pickup in the neck. But how should I install the SuperDistortion? Can I just use a normal Jaguar wiring diagram and simply replace the Jaguar bridge pickup by the DiMarzio? Or do I have to change/add/leave pots, capacitors, resistors??
I really hope you can help me out here!
Thomas
Grey Garden
Post by Grey Garden » Sat Apr 09, 2011 8:13 pm
Here is a link to the electrical upgrade work I perform on my MIJ/CIJ even Masterbuilt Offsets:
http://greygarden.org/ShieldingAndStarG ... yGardenWay
-Adam.
"Argue the point until there's no point in arguing." -Adam.
OffYourFace
Post by OffYourFace » Thu Aug 25, 2011 12:06 am
Klein makes JM & Jag pickups now... I bought a set of their 1954 Strat pickups and they're great!
https://www.kleinpickups.com/c-26-misc- ... ckups.aspx" onclick="window.open(this.href);return false;
ChrisFFTA
Post by ChrisFFTA » Sun Nov 20, 2011 9:39 pm
Anyone know of drop in replacements for Jag pickups that arent Jag pickups. Novak does some listicks but I was thinking humbuckers?
noisepunk
Post by noisepunk » Wed Dec 21, 2011 1:19 am
These were wound by an OSG member- same guy andrew's getting his pickups from for his last couple builds. I'm not sure if he's gone public yet, but they just sound so damn good I couldn't contain myself :blush:
http://snd.sc/uqLRWo
They tried to give me advice, down at the record shop. I said "Sit down boys, this may come as a SHOCK. But alls I listen to, it's all freedom rock."
Filipe
Post by Filipe » Mon Jan 16, 2012 9:01 am
Hi! I'm looking to replace the pickups in my CIJ Jaguar and need some advice as I'm new to this. I've been reading a lot on this forum and learned a lot already, but I'm still not really sure about some things.
I play mainly postrock and I actually like the sound of the neck pick up, but I never use the bridge pickup as I think it sounds really bad. Another problem I have is that the jag starts squeeling really loud when I turn overdrive/distortion on, it's not a problem as long as I'm playing, but I can't let chords ring with the distortion on, which is a bit stupid.
Now, there's a guy on a local website selling an SJAG-1 neck pickup and an SJAG-2 bridge pick up for cheap. I figured that would be a good upgrade as I like the sound of the neck pickup on my jaguar and would like the bridgepickup to be more punchy, but it is recommended to use this combination? or will the bridge pick up be much louder? And will this resolve the squeeling problem or are there any other recommended mods to solve this?
Thanks in advance!
Johnny Z
Post by Johnny Z » Sat Mar 17, 2012 4:24 pm
I haven't seen much talk about the CPJM pickups. I would like to know more about them. I have them in my guitar and as far as I can tell sound pretty nice. I know they have bar magnets and the adjustable poles seem like a good idea. Anyone know if the magnets are ceramic or alnico? Not that I plan to change them but if I did what would be a good choice for a Jazz guitarist. BTW: I really like the mellow sound of the rhythm circuit, I think that sets the guitar apart from Strats and maybe even the Jaguar.
Thanks
gibs
Post by gibs » Tue Mar 20, 2012 2:05 pm
does anyone have an opinion/description of the GFS JM pickups, both vintage and overwound? Really curious if there worth it or if its a better shot to go with SD or Novak
Johnny Z
Post by Johnny Z » Sat Mar 24, 2012 4:21 pm
gibs wrote:does anyone have an opinion/description of the GFS JM pickups, both vintage and overwound? Really curious if there worth it or if its a better shot to go with SD or Novak
Hi gibs. Seems like were following the same threads.
I asked GFS, about their pickups, thought about trying some but their not RWRP which means more noise in the middle position. Here's their reply:
Hi,
The neck pickup is not RW/RP so they will not cancel noise in the middle position.
Curtis
Guitarfetish.com Tech Support
If I have a choice it's gonna be hum-canceling in the middle position. FWIW if I were to swap my pickups I think I'd go with Seymour. Saying that I'm getting to like the CP pickups, I don't need the extra gain and they have a nice clear tone for Jazz, not quite like a Humbucker but very nice. A tweak of the tone controls guitar/amp makes all the difference I need. Maybe if you're playing Hardcore hotter pickups would be an improvement?
mrfrumpy
Post by mrfrumpy » Sun May 06, 2012 8:10 pm
Can someone help me...
I have a set of Lace Hemi pick ups that I wish to install into a jaguar project. What diagram can I use ? I will have the wiring done stock standard... any help accepted.
