What to do about rust.
- InsertNameHere
I've noticed a while ago a little rust showing up on one or two of the strings on my guitar and a bit on the bridge. I figured I would take care of it some other time.
Well a couple of shows later I noticed it was getting a bit worse, but I packed it up and headed off to college. Taking it out to play now though I notice that a bit more of the bridge has rusted, a lot of the screws on the body are rusted or are starting to rust and even the tuners are rusting where the string is wound around them.
I know the bridge and the tuners I can probably give a decent rubbing down to get rid of, but should I replace the screws for my fretboard? Like, will it cause a problem for the body of the guitar if the screws are rusty?
I don't care about my guitar looking nice or anything, I just don't want it to break on me.
- shadowplay
Re: What to do about rust.
If it's a Jag or a JM a rusty bridge is actually a good thing because it keeps buzzing and other sundry annoyances in check. I wouldn't worry about any rust in a guitar, it will always happen sooner or later. If you don't like rust I imagine a relicer might swap you for a new part.InsertNameHere wrote:I've noticed a while ago a little rust showing up on one or two of the strings on my guitar and a bit on the bridge. I figured I would take care of it some other time.
D
Are you loathsome tonight?
- ChrisPee
I only ever worried about rust on one of my Jaguars....but it was a 1969 420G, which is more of a concern. Rust on a car is not really seen as relicing when it comes to MOT time
Okay okay, sorry this was pointless and no help what-so-ever.
- the older brother
You have screws holding the fretboard? What type of guitar is it?
Rust is just part of time. Seriously though, Nevr-Dull works like a charm.
- Zero_
A very nice trick to remove rust:
Soak some aluminium foil (the one from the kitchen will do) in water for a couple of minutes and then rub it over the rusty parts. I once removed heaps of rust from a guitar I bought in a pawn shop with this method, it works great.
At the end, just wipe the aluminium/rust particle sauce clean and voilà!
- wardpike
Cocacola and steel wool. Universal remedy for removing rust and leaving the metal intact. Rinse after washing!! Cold clean water to clean off the coke.
- SPudnik
- wardpike
LOL! But I wouldn't spray a guitar with WD40.
