Depth of the Jag mute slug hole?
- the older brother
Anyone have a measurement of that?
As I'm quite noob with jags and are about to add the mute (RI) to a CIJ Jag I'd like to know what's the depth of that hole. I guess it is different on AVRI's and vintage ones as the screws/springs are very different, so the depth od an AVRI would be the best.
Thanks!
- Jerker
Thanks!
- Jerker
- RumorsOFsurF
Re: Depth of the Jag mute slug hole?
Good question....
I'd take my AVRI apart, but the slug doesn't come out when I remove the mute. It's still recessed way below the surface of the body....I don't know how I'd get it out without damaging the surrounding finish.
Damn kids, get off my lawn!
- sookwinder
The problem is ... is the spring used in the 60s was longer but with a lower value "k" (Force = k.distance compressed).
So if you have a vintage spring/slug then the top of the slug is usually level with the top of the guard... but will sit compressed as little because the slug will normally sit under the guard.
for mordern repro springs/slugs I suspect the depth of the hole is still the same as the vintage, but the spring/slug sit lower (modern spring is shorter) .
I have a feeling the depth of the hole is approximately the same depth as the trem and main control routes ... about 36mm
each time I have drilled a hole for a mute/slug I have drilled it about 30mm , the tried to fit the mute and kept on lowering the hole depth until the mute fitted/worked.
- the older brother
Thanks David.
You think the AVRI is the same as the Vintage - I ask Doug how deep the hole on his pink piece of wood is!
- RumorsOFsurF
David, you are a wealth of Jaguar info ...
- the older brother
If anyone else is lurking and want to know:
According to Doug is the mute slug hole ~35mm on his Shell pink Jaguar - or as he pu it himself:
Thanks boys!
So Sook is absolutely correct when he's assuming same depth as the trem route - 36 mm (you have to bear in mind that Dougs Jag is sanded down to bare wood at least three times (two by himself and one back when it was stripped for poo finish the first time) - so that have very likely taken that last mm.1 3/8" which I believe is 1.375" or 34.925 mm...
Thanks boys!
- fullerplast
Yeah... and dont forget the toothpick method is not exact. I was thinking 35 mm or whatever the main cavities are. Sook is right on... if not exact!the older brother wrote: If anyone else is lurking and want to know:
Thanks boys!
Q. Are we not men?
- DWO
Great info in this thread.
- N0_Camping4U
It appears, but I would suspect cannot be so, that the vintage Jaguar mute is very similar tot he vintage bass vi mute; anyone happen to know the minuet differences?
