Is there a way to center the arm insert part of the trem assembly? Mine is rubbing on the south end of the insert hole.
https://imgur.com/a/wIQ1sEA
Trem arm not centered
- DrippyReverbTremolo
Re: Trem arm not centered
Is that with the vibrato under tension (i.e. with the guitar strung up to pitch)? I only see that when there's no string tension.
Looks like there are no strings installed in that picture.
So yeah, can be 'fixed' by stringing up the guitar as DrippyReverbTremolo alluded to.
- RumorsOFsurF
If it is under tension, you need to adjust the screw until it floats. It could just be that the screw is tightened all the way, causing the trem to be all the way up against the base plate.
Damn kids, get off my lawn!
- blimpsgo90
Ugh… my oversight. I feel like a goof. I was changing strings and not thinking this through. Thanks for pointing it out. All good.
