Wiring help: Idea for rotary switch
stafflod
Post by stafflod » Sun May 05, 2024 2:48 am
The idea is to replace one of the pots in the Lead circuit with a 4p3t rotary switch.
I rarely use the tone knob so I figure I will let that one go, if I need a tone knob I will mod the Rhythm circuit and replace the 50k tone pot with a 1M one. I'm always been fascinated by Rotary switches and bought a couple when I was dabbling with a Jazzmaster XII. I never put them to use due to no know-how.
I have had a recent spell of energy so I figured I'll put them to use - only to find out:
1. they don't have solder lugs like regular pots
2. they are 2p3t which doesn't solve what I want to do... I have to use them in another project... 8)
My idea:
Let the rotary switch have 3 modes:
1 both pickups in parallell (normal mode)
2 both pickups in series
3 bridge pickup out of phase
The rotary switch will go into the PU selector. I've done the 'both pickups in rhythm circuit'-mod on two JMs and will keep that.
So I've taken two DPDT switch schematics and worked my rotary switch from that. I have no background in electronics so it might be full of errors...
Here's a schematic I've found which is the basis of the Series Mode
So I want to combine the two DPDT schematics for mode 2 and 3
This is my layout for the rotary switch
I think I might have to add a ground to the bridge pickup at some stage.
Cheerio
//Staffan
Futuron
Re: Wiring help: Idea for rotary switch
Post by Futuron » Sun May 05, 2024 5:09 am
Interesting! I think I understand what you are doing. You've done all the hard work! What I can see at least:
You have no B- to ground on positions 1 or 2, and no N- to ground on position 3. You also have used 2 wires where 1 would do (and need that pole free to complete the ground connections). So this is what I would change it to. 2 wires removed, 5 added. (I also wrote N+ on there because I accidentally cut off your note on the screenshot.)
This should give you
1. N+ to NS, N- to GR, B- to GR, B+ to BS.
2. N+ to NS, N- to B+, B- to GR, NS to BS.
3. N+ to NS, N- to GR, B- to BS, B+ to GR.
edit: I think you can do even simpler but it's late - I need to sleep!
stafflod
Post by stafflod » Sun May 05, 2024 5:19 am
Wow! Thanks for the reply! I will give it a closer look tonight :)
stafflod
Post by stafflod » Sun May 05, 2024 6:41 am
Maybe something like this?
Nudger
Post by Nudger » Sun May 05, 2024 10:11 am
Have you considered a 4 way rotary
I have used this one many times.
https://www.ebay.co.uk/itm/385631730443 ... media=COPY
Heres two of my high tech diagrams.
N - N/B Series - N/B Parallel - B
N - N/B Parallel - N/B Parallel "out of phase" - B
If you go with 1st drawing, you could add a OOP switch giving 5 different settings, Ive squeezed a switch between the pots before now..
stafflod
Post by stafflod » Sun May 05, 2024 1:11 pm
Nice colours! The 3-way mindset came from my original switch that I bought before (not even knowing what I bought….), I’m open for anything really.
stafflod
Post by stafflod » Sun May 05, 2024 1:16 pm
Nice Marauder build btw. Mine is still unfinished (thinline without f-hole and 25” scale). I glued the fretboard to sparsely and the truss rod lifted it.
One thing is that I still want to keep the 3-way toggle switch and not replace that with the rotary switch. Just the rotary as a supplement.
Futuron
Post by Futuron » Mon May 06, 2024 1:05 am
That looks like what I had in mind!
stafflod
Post by stafflod » Mon May 06, 2024 1:40 am
Cool! thanks for the feedback and help!
