Fender ULTRA String Guides?
- OffYourFace
- thisisnickpaige
Re: Fender ULTRA String Guides?
I mean, they guide the strings. Haha
I played an Ultra Strat and was not kind to the trem. It held and glided the strings just fine; stayed in turn perfectly, as well. I guess I can give them a vote of confidence.
Any particular reason you’re goin’ after these ones? They do look cool after all.
Jesus
- DrippyReverbTremolo
I put them on my home-built JM because Iike the look of them. They perform as they should.
- GilmourD
I put them on my Enterprise Jazzmaster at least partially because they look futuristic. I believe they are supposed be a functional improvement, however, due to the smoother bottom surface not giving the string anything to catch on. I've been happy with them.
- OffYourFace
Hmmm, well I just came back from Geetar Center. I had to get some strings so I played a ton of new Fender strats. On one guitar (a Pro II) the B & E strings kept pinging behind the nut and it wasn't the nut's fault. Other guitars were fine. I guess they don't really work any better than the vintage style guides.
I wanted to try something new but I think i'll stick with these cuz they just always work for me.
How do you know the pinging did not come from the nut slots?OffYourFace wrote: ↑Sun Apr 28, 2024 2:17 pmHmmm, well I just came back from Geetar Center. I had to get some strings so I played a ton of new Fender strats. On one guitar (a Pro II) the B & E strings kept pinging behind the nut and it wasn't the nut's fault. Other guitars were fine. I guess they don't really work any better than the vintage style guides.
- OffYourFace
the slots were kind of wide so the strings didn't get hung up on them. it's possible that the guides weren't polished enough underneath or one side had a bur. Who knows. I might still get some, they're cheap.DrippyReverbTremolo wrote: ↑Sun Apr 28, 2024 9:45 pmHow do you know the pinging did not come from the nut slots?OffYourFace wrote: ↑Sun Apr 28, 2024 2:17 pmHmmm, well I just came back from Geetar Center. I had to get some strings so I played a ton of new Fender strats. On one guitar (a Pro II) the B & E strings kept pinging behind the nut and it wasn't the nut's fault. Other guitars were fine. I guess they don't really work any better than the vintage style guides.
- Flurko
Never used it but I like how it keeps the originals silhouette while seeming more functional.
Never had tuning problems with it but I disliked how cheap the bent metal "butterfly" looked on my JM so I went for a dynaguide.
It functions really well and the whole rocking motion following the strings fits thematically with the original idea of the Jazzmaster bridge.
- GilmourD
I had a nut where the G string slot was SUPER wide, but not flat on the bottom, so even mild vibrato would cause pinging as it went over a ridge in the middle of the slot. I tried cleaning up the bottom but could never get it right without going too low and it wasn't a bone nut or anything so I just put a TusQ nut on there, massaged the slots to the right heights, and called it a day.OffYourFace wrote: ↑Sun Apr 28, 2024 11:57 pmthe slots were kind of wide so the strings didn't get hung up on them. it's possible that the guides weren't polished enough underneath or one side had a bur. Who knows. I might still get some, they're cheap.DrippyReverbTremolo wrote: ↑Sun Apr 28, 2024 9:45 pmHow do you know the pinging did not come from the nut slots?OffYourFace wrote: ↑Sun Apr 28, 2024 2:17 pmHmmm, well I just came back from Geetar Center. I had to get some strings so I played a ton of new Fender strats. On one guitar (a Pro II) the B & E strings kept pinging behind the nut and it wasn't the nut's fault. Other guitars were fine. I guess they don't really work any better than the vintage style guides.
