What's the best way to ground your aftermarket aluminum parts?
- dangayle
I've got some pickup covers from Funked Up Guitars and a Herad pickguard, what's the best way to ground them?
- madlovepickups
Re: What's the best way to ground your aftermarket aluminum parts?
Star washer on the jack for the Herad pickguard. A wire soldered to a solder tag washer mounted with a spring on one of the pickup mounting screws for the covers?
- madlovepickups
If you have shielded pickup cavities the mounting screws may ground the covers anyway. Best to check for continuity with a multimeter.
- GilmourD
I've generally cleared some of the anodization off around all the pot, jack, and switch mounting screw holes so that way everything is grounded without having to run ground wires to everything. Then I make sure that my copper shielding in the body has continuity to the pack of the pickguard by also clearing off the anodization around a few of the pickguard screw holes and making sure there's copper tape there.madlovepickups wrote: ↑Wed Mar 20, 2024 1:00 amStar washer on the jack for the Herad pickguard. A wire soldered to a solder tag washer mounted with a spring on one of the pickup mounting screws for the covers?
- dangayle
Oh, I didn't even know that solder tag washers were a thing. I'll have to get some.madlovepickups wrote: ↑Wed Mar 20, 2024 1:00 amStar washer on the jack for the Herad pickguard. A wire soldered to a solder tag washer mounted with a spring on one of the pickup mounting screws for the covers?
