Need help with HS Mustang wiring diagram
RoséBear
Post by RoséBear » Sun Dec 31, 2023 8:42 pm
Hey guys,
So I wanted to rewire my cobain mustang with Lace sensors. I’ll have a red/blue in the bridge and a gold in the neck. I wanted the two switches to function as follows:
Top switch (closest to neck) bridge/both/neck
Bottom switch: (closest to bridge just for humbucker) bottom coil (red)/full humbucker/top coil (blue)
So essentially, the top switch is a 3 way, the bottom a coil tap that takes advantage of the mismatched colors
