Hi,
The bridge of my CV Jaguar is nearly touching the pickguard but I'd like string action to be lower. What should I do?
Just to be sure: to lower/raise the bridge (it's a Mustang bridge) I use the small Allen key right?
Thank you!
Cheers
Squier CV Jaguar - Bridge very low
- soul1
Re: Squier CV Jaguar - Bridge very low
Yes, use the small allen key in the two small holes on each side of the bridge to raise it (or lower it).
- Horsefeather
If that doesn't do the trick you can also put a shim at the very end of your neck heel.
- adamrobertt
You need to shim the neck. Buy one of these and pop it in the neck pocket. You probably need 1 degree. This will allow you to raise the bridge but still have a low action. IMO it is an essential part of properly setting up a Fender offset.
- jgpouton
Thanks a lot! I will buy a shim.
The small Allen key can enter the left post but not the right one where it turns without resistance...
Cheers
Cheers
