Hi, everyone!
I have a peculiar problem with a Jag I own. The neck pickup became really quiet. It measures 0.85 K at the output jack, doesn't matter if I use rhythm or lead circuit. So I unsoldered it and measured the pickup itself and it gave me healthy 6.5 K! Soldered it back in - same issue!
Earlier today I could have sworn the rhythm pickup worked fine again, but then the output went done again
Any ideas what could be wrong with the wiring or components? Thank you!
Jaguar's neck pickup's low volume (0.85K)
- vbara
Re: Jaguar's neck pickup's low volume (0.85K)
The key to troubleshooting is understanding the circuit in relation to the symptoms. Your neck pickup's DCR tests out OK isolated, but it doesn't function properly in circuit, on either the rhythm or lead circuits. The only components shared between those two circuits are the neck pickup, the rhythm/lead switch, and the output jack - see below. But the bridge pickup also shares the output jack and is seemingly OK, right ? So I would be looking at the rhythm switch first. Undo the plate and inspect the wiring there. See if the symptoms change with it out of the guitar. It would also be worth connecting your neck pickup direct to the guitar cable, to verify that it is actually OK (highly likely given the DCR reading) ... maybe jiggle its wires as you do.
- ChrisDesign
Yep. Check the switch wiring. If the neck pixkup is poorly soldered that would do it. If the bridge pickup is ok then you know the pots and everything post switch is ok.
