And if the mechanism is, apart from the looks and the arm, essentially the same as the original, you could just tighten the spring to lower the plate/strings, right?Haddock wrote: ↑Tue Jul 16, 2019 8:32 amI agree, but note the bridge is set as low as can be on this picture.alexpigment wrote: ↑Tue Jul 16, 2019 7:35 amThe resting position of the trem seems to make the strings roughly as high as they would be at that same point on a vintage trem. Visually, it looks like the break angle is unchanged to my eyes.
Göldo Tremolo for offset guitars
- kimson
Re: Göldo Tremolo for offset guitars
- alexpigment
Not sure that's possible, but I have a feeling you're going to lose tremolo arm range if you were to do that. I suppose you could bend the arm upward, but still.
- ludobag1
first the arm miss lenght
2nd the plate have a nut ! then a new cause of friction
the string seems up all the time ,the break angle is not here then need a shim for sure
the range of up and down seems to be not better than the old ?
seriously to my taste it is not beautiful
will it feet in a case ?
ect ...
need to be test to see
ect ...
- jorri
sure looks like a flat zero degrees break angle, but images can be deceiving..
- ThePearDream
That looks
It would have to be the best performing vibrato unit ever devised before I'd consider putting that on any of my guitars.
Doug
@dpcannafax
@dpcannafax
- jorri
On another guitar it might be ok. Like the bigsby, weird italian or japanese semihollows. Patched into a jazzmaster like its infected by tesuo the iron man is not.
- tdbajus
I think you are trying to say something negative, but it's just made me want it more.
I had a group called Tetsuo The Iron Band.
Surprised nobody has pointed out that it's basically a hagstrom vibrato transplanted into a JM mounting plate.
Throw in some goldfoils and I could get into it, but only because I like hybrid design guitars. I wouldn't want that on an otherwise "normal" JM or Jag.
- VPO
That would look really nice on old Teisco or something like that.
- tdbajus
I've never used one before- are they any good?mbene085 wrote: ↑Wed Jul 17, 2019 3:28 pmSurprised nobody has pointed out that it's basically a hagstrom vibrato transplanted into a JM mounting plate.
- supersonicjazzmaster
Göldo is a well known brand for guitar parts in Germany since many years.
Normally their products are high quality.
When I saw this trem unit my first thought was: Oh, the Jazzmaster looks damaged... what happened to the nice trem unit area?
It is still my first idea...
Anyway, I personally don´t like the look.
But I have the question: Why?
For what?
Money?
For what?
Money?
It starts... when it begins.
Ralf Kilauea
Ralf Kilauea
- Fiddy
That's a hard no from me. Looks fugly. Would look better with a non Jazzmaster shaped plate.
- Roger de Berg
When it comes to the trem arm: This arm is fully adjustable in length and angle.
- Roger de Berg
- Roger de Berg
The arm is fully adjustable, and the tip does not move downwards, when both mud screws are tighten
