String wind ends before the tuner, only core wraps
PorkChop
Post by PorkChop » Sun Jan 20, 2019 10:00 am
I decided to try the Tenorio strings. JAG52s. 11-52. They seem great so far. Stretched once and only the high E has needed retuning. The D string wind doesn’t make it to the tuner though. Just the core is wrapped on the post. Has anyone had this experience with a string before? It sounds fine. Just wondering if the wind will start to unravel or loosen and cause the string to get squirrelly. Thanks.
minimumnishe
Re: String wind ends before the tuner, only core wraps
Post by minimumnishe » Wed Jan 23, 2019 11:01 am
Don't worry, they're supposed to be like that. A JM set that I tried a couple months ago had the wraps all end in between the nut and the tuners, no issues.
