Hi
I have built an ES-355 tribute clone from a kitset
I've added a vintage Bigsby and Seymour Duncan, nitro lacquer, antiquity Humbuckers - mojotone caps etc
and a Varitone that I had a guy online (via ebay) to build for me
He was making and selling bass varitones
I supplied the specs for the capacitors directly from Gibsons website:
Positions 2-6 traditionally cycle through 1000pF, 3000pF, 0.01μF, 0.03μF, and 0.22μF capacitors.
http://www.gibson.com/News-Lifestyle/Fe ... itch!.aspx
But after installing the varitone and hooking it up - its working in reverse
And I don't mean that the positions of the caps are reversed, the caps are working in reverse
A Gibson Varitone cycles from Position 01 (bypass) to 06, each click makes a high pass, which filters bass more on each position 2-6
But on my one its a series of low pass filters - I've made a video to demonstrate (link below)
I'm wondering if anyone has a suggestion for caps I could use to achieve the desired effect?
Basically the idea is the same as the high pass filter on a jaguar - but in five steps
I'd say that the variance in bass cut from position 2 - 6 overall would be at least double the bass cut that my Jaguar makes with its one switch
So each cap would be around 1/4 the value of a jaguar cap?
I don't need it to be vintage correct in any way.... just want to dial in more of a single coil type sound in varying degrees
Paspallum
Clip https://www.youtube.com/watch?v=o55oi8avCUE
High pass filter Varitone for ES355
- paspallum63
Re: High pass filter Varitone for ES355
I'm not a varitone expert, but I understood it to be a switchable notch filter, not a switchable high pass filter. ie each switch setting filters out a notch of different frequencies within the spectrum (allowing those above and below to pass), not all the frequencies below a given frequency (allowing only the higher frequencies to pass).
But when that notch setting covers mainly lower frequencies, it could sound rather like a high pass, because there is not much left 'below' the notch. LIkewise when the notch covers mainly higher frequencies, it could sound rather like a low pass filter.
One of the most common notch filters in elec engineering is a 50/60hz notch filter, ie a very narrow notch that filters the hum around the mains frequency but allows everything below and everything above 50/60hz to get through.
I don't know enough to say exactly how each step of the varitone should sound, so I'm not saying your guy may have done something wrong, but I take it he followed the standard ES-345 circuit, at least in its mono form, one half of that below, with choke, caps, and resistors ? ...
- oid
It is meant to be a notch, rather bent shape, more of a low shelf with cut, followed by a slight notch with a peak on the high side and followed by a high frequency shelf at 0db, going off memory in that, but it is more or less right.
I think everything below the notch is down around -6db and the notch frequency down another 6.
After work I will refresh my memory on the varitone if a solution has not been worked out by then.
- paspallum63
Thanks for your replies guys
I'd be pretty happy just to have some caps that do different hi pass filtering just like a jaguar - but I have the chance to have 5 caps of different values
I'm not trying to create an authentic replica of a 60's Varitone
Paspallum
Paspallum
- novamax
Just a thought: A cap within the signal path filters out low frequencies from signal out (jag strangle cap). The same cap parallel to the signal path filters out low frequencies from bleed-to-ground, leaving only those low frequencies for the signal (tone cap).
Have you checked whether the caps' out is really going to signal out (instead of going to ground)?
- oid
Pretty sure my description of the varitone was wrong, think it is flat to the notch with a peak of a few decibels before the notch and a good peak after the notch then going into a lowpass, something like that anyways, google will clear it up for those who are curious, certainly not a highpass though.
Your logic is correct but that is for a Highpass or Lowpass filter, the varitone is a notch filter.novamax wrote: ↑Wed Nov 28, 2018 10:31 pmJust a thought: A cap within the signal path filters out low frequencies from signal out (jag strangle cap). The same cap parallel to the signal path filters out low frequencies from bleed-to-ground, leaving only those low frequencies for the signal (tone cap).
You can just switch between five different caps in the standard jag strangle circuit, I assume since you paid someone to wire it up for you a quick description of what to do will not help you much. Starting a new thread asking for help switching caps in the strangle circuit should get you some assistance quicker then I can offer right now, or search the forum abit, someone may have done it already. A browse through this thread may prove fruitful and be a good starting point.paspallum63 wrote: ↑Wed Nov 28, 2018 6:41 pmThanks for your replies guys
Paspallum
- novamax
Just putting a switch into signal path between PUP selector and tone/vol circuit should be fine, usually something like:
PUP selector out -> x5-switch -> cap {1/2/3/4/5} -> vol pot in.
