Thanks, Windmill! So, I have an AVRI 62 Jaguar. You think the different cavities aren't connected to the ground like in the case of the Japanese bass? Ok that's possible of course - but it kind of restates the same thing, which is that it was always like that and I had not noticed it before. It's of course possible, I'm just surprised that I had not noticed it after all these years.windmill wrote: ↑Sat Sep 01, 2018 5:39 pmOur friend Dave has an answer for your humming problem
https://www.youtube.com/watch?v=Qp-zFLylafE
After watching the start skip the work on the neck and go to around 4 min 40secs on the video.
HTH
Jaguar New Vibrato and Bridge setup and hum issues
- kgbAttack
Re: Jaguar New Vibrato and Bridge setup and hum issues
- windmill
If it wasn't happening before it becomes a matter of retracing your steps until you can locate where the problem is, ie what was changed, possibly by accident, when you did your work.
Check that all the shielding is connected to a ground.
Experiment with alternative ground wires from the trem to the ground.
It will probably take a bit of trial and error to isolate the cause of the problem.
HTH
HTH
