VMJM mini pots
- gloeb
VMJM mini pots
The volume pot on my VMJM is in need of replacement. I can't, however, find the 1meg, split shaft, mini pot that is in it anywhere. Has anyone been able to buy replacements that do not require widening the pot hole in the pickguard?
- Killerferns
Re: VMJM mini pots
I had the same problem. However when i actually experimented, i found that standard sized pots did actually fit without modification to the pickguard.
I'm not sure If my VMJM is a bit off a weird one though because the rhythm roller bracket was standard size too. Mine was made in 2017 and new when i got it. Maybe they changed the parts. I understand Squier are nothing if not inconsistent.
Might be worth trying a standard pot though if you haven't already.
In my search for mini pots i could only find 500k ones. I think they were Alpha.
Good luck!
Paul
Good luck!
Paul
- gloeb
Re: VMJM mini pots
Dang, I did try with a standard size CTS, but I believe my jm to be an earlier 2007ish. I'll try again though. Thanks, Paul!
- Killerferns
Re: VMJM mini pots
I doubt it would take much to widen the holes though. A reamer, drill bit (hand held), file or even sandpaper should it.
It is strange about the lack of 1 meg minis though ...
- Debaser
Re: VMJM mini pots
Like mentioned, the guard hole is easily opened up if need be. But if you must have that kind of pot, does this work?
https://www.ebay.com/i/132091361388
- gloeb
Re: VMJM mini pots
That does seem to be the right size. I think I'll try to open it up since I already have a standard size one.
Thanks for your help
- Witchburner
Re: VMJM mini pots
Can confirm this works, done it to mine without any issue. the mini pots also went south, both circuits actually
