mastery bridge and buzz stop
- northernlights
hey guys! i got my new american original 60's jazzmaster and replaced the bridge with mastery. i applied what mastery says but i hear sometimes buzz mostly top strings. i didnt do anything with saddles, should i leave that way or rise them little bit without ruining the radius? and what're your thoughts about buzz stop? is there anyone using them? I saw all nash guitars come with buzz stop.
Re: mastery bridge and buzz stop
If you use a buzz stop, much of the point of the mastery is lost.
It's possible that the break angle is insufficient, and that shimming the neck and raising the bridge could help.
- parry
How much is a Buzzstop? $15-ish? Seems like a no-brainer, to at least try. If it works for you, that's awesome! You get to enjoy playing your guitar
Where's the buzzing coming from? Sounds like it just needs a setup.
I assumed it had been set up, but absolutely, this is the basic first step before troubleshooting anything!marqueemoon wrote: ↑Fri Feb 09, 2018 6:37 amWhere's the buzzing coming from? Sounds like it just needs a setup.
- northernlights
i dont know, i setted it up but not sure that i did everything as i said i didnt touch the saddles, and they move right and left side just a little bit freely lol i really like mastery than stock bridge but that buzz thing made me upset. maybe it's because of the strings. i'll change the strings and try again.mbene085 wrote: ↑Fri Feb 09, 2018 6:41 amI assumed it had been set up, but absolutely, this is the basic first step before troubleshooting anything!marqueemoon wrote: ↑Fri Feb 09, 2018 6:37 amWhere's the buzzing coming from? Sounds like it just needs a setup.
Probably the annoying intonation springs rattling causing the 'buzz'.
Both of mine did that until I sleeved them with (clear) heatshrink tubing. Oh, and then I sold them.
