Replace Jaguar string nut
- airtom
I am building a Jaguar Classic Player HH. I am using a Squier jag neck and it fits absolutely perfectly in the Fender RI body. I would like to replace the plastic string nut. What should I get...I'm pretty sure the Squier Jag neck is 9.25 radius. I don't know if it is a flat or radius base nut. I am looking for specific recommendations on type of material, vendors, brands...anything to make it easier to wade thru the plethora of choices. I don't know if other Fender guitar model nuts fit or not. Total newbie to this aspect of guitar maintenance. What would you do...other than take it to your local luthier . Changing the nut is supposed to be a relatively easy job from what I've researched so far. Suggestions please!? Tom
- airtom
Re: Replace Jaguar string nut
OK, I called Fender in Ca. and the gentleman told me that a standard Strat string nut will work. My radius is 9.5. I guess I will just order a Graph Tech TUSQ for a Strat and call it good. We shall see. Tom
Replacing a nut is usually not a straight up 'replace and call it good' exercise.
The pre-cut nut slots are just a guide for string spacing. You need to cut the slots to the correct depth for the fret height/radius specific to the neck its being installed on.
- airtom
The TUSQ XL 5000-00 for Strat that was recommended by Graph Tech that I got does not fit snugly. Even though my Squier Jaguar neck has a flat nut groove the TUSQ has the tab on the bottom which allows you to use it in a flat groove neck. However, it can rock back and forth (headstock to body) ever so slightly in the slot. Too loose in my opinion. There is .005 difference in thickness between the original Squier plastic nut and the TUSQ. The string grooves seem the same and the height is perfect I think. The width was slightly wide so I sanded the edges to fit. Don't know why the slight difference in thickness. On Graph Tech website I compared the various nuts and the one for a flat groove is thinner yet. After messing with it and talking to Graph Tech again I reinstalled the original. Tom
Indeed. First time you fiddle with nuts there's something to be said for buying a few cheap pre-slotted synthetic bone nuts on ebay and seeing what issues you may face when making a final decision about (more expensive ?) nut replacement - size, nut slotting etc.
