Is there a good source for the foam that goes under the pickups? Something with the right thickness and sponge/stiff ratio?
Maybe something easy to find at Home Depot or Lowes?
Thanks!
Good pickup foam (underneath) source?
- backporchmusic
- HNB
Re: Good pickup foam (underneath) source?
The foam to seal around doors is pretty good stuff.
https://www.lowes.com/pd/Frost-King-10- ... ip/3047980
Christopher
Lilith Guitars
Lilith Guitars
- backporchmusic
Perfect, thanks.
- fisonic
https://m.lowes.com/pd/M-D-13-ft-Expand ... ip/3434324
Also from the same supplier, if you want something a bit thicker.
Lifetime supply.
Lifetime supply.
