12 string mustang??
- palesnow67
12 string mustang??
Can you install a warmoth 24in 12 string neck into a mij 69 reissue mustang body? I think it'd be a cool idea. Or maybe i'll get a squier vm mustang body off ebay since the body is a bit thicker. either way has this even been done yet??
10. Signatures must be no more than two lines.
- N0_Camping4U
Re: 12 string mustang??
You'd need a new bridge too obviously... Is it possible? Well, with enough time, money, and effort....
- bgalizio
And a different bridge location. The Warmoth 12 string necks are 25.5" scale. The mustang is typically 24" scale.
- MattK
If the intonation was close, you could just use a Jag/JM bridge since two strings could sit side by side in the threaded saddles.N0_Camping4U wrote:You'd need a new bridge too obviously... Is it possible? Well, with enough time, money, and effort....
- N0_Camping4U
I feel like someone else would have done that if it was that easy and worked properly. I feel like it my kill your strings resonance a lot.
Hey, I'm staying tuned, I hope you go for it, I'd like to see it.
- rumfoord
My instinct is that it'd be neck heavy. But also you might be better off starting with a duosonic / hard-tail mustang body in order to have more options for the bridge.
- rumfoord
- lammie200
I installed a Warmoth Jazzmaster neck onto a Fender Jazzmaster body. I had the neck retrofitted with six additional tuners. There is a guy on Ebay that advertises his services to do it. I supplied the neck, so I think that charged me about half of what he advertises for. The guitar turned out great. Obviously the headstock is heavier than a 6 string, but the comfort of the Jazzmaster body kind of offsets any negative balance issues.
Strat Kinman KITA set, Tele SD Seth Lover neck only, Jazzmaster Kinman Thickmaster set, Jazzmaster 12 Rose Picasso set, Martin SC-13E Special, Gibson ES-390, ES-165 490R, ES-165 BJB, Henriksen Jazz Amp x2 for Stereo
- N0_Camping4U
Have any pics of it?
- bacca51
You could have someone build you a 12 string with the right scale length, or you could move the bridge on your body and use a warmoth neck. Ive seen people use a regular jm/jag bridge for 12 strings, intonation wont be perfect but thats part of the wobbly 12 string sound!
- palesnow67
Omg i forgot i even posted this LOL
Nah i havent worked on this, I'd loev too but it's too much work honestly.
BUT i have a surf green jag im turning into a 1965 spec. Already got the mute and brass shielding
here is the post
viewtopic.php?f=8&t=105444" onclick="window.open(this.href);return false;
here is the post
- mackerelmint
- palesnow67
WTF is that vintage also?? what an idiot.
No if i did it, i would get the warmoth 12 string neck that looks like the vintage ones
