Do you put tape around the bridge posts?
- Puke+Cry
Re: Do you put tape around the bridge posts?
nah i didnt have any problems up until my trem broke
- luau
- Admin
This is kind of what I was driving at above. If the posts need taped, the guitar isn't set up properly IMO. Some kind of lube or other on the nut is a good idea too I think. I use a sharp #2 pencil and basically just color the slots. Oiling or otherwise lubricating the bridge where the strings make contact with the saddles would be bad.jetset wrote:If your bridge is not returning to center, it's not the bridge's problem. ...
Bigger in sum than parts.
- Val66c
I use the pencil trick too.
