laurencestutz wrote: .. neck has vintage frets and a 7.25 radius ( i believe! ) and so i'm thinking this is kinda what i like ..which i know the AVRI is.I'm a rhythm player really..and so was a bit worried that i might notice this different neck .
I think most primary-rhythm players would prefer the vintage spec guitars. It is less tiring on the fingers to play barre chords for long periods on the vintage spec neck. And you won''t feel the frets hitting the bottom of your hand so much when you switch chords. The primary advantages of the flatter radius and the bigger frets come when playing lead.
So in your situation I would not get a CP unless I had played it first.
laurencestutz wrote: Also a big attraction for me is getting a guitar with a trem..so i can do some atmospheric stuff..and don't want to pick up a CP for that reason if it ain't great...
I have a CP Jaguar and I use the trem on it, it works fine. I can't compare it to the vintage spec guitars though because I don't have them. (And don't have a Jazzmaster). Well actually I do have a vintage Fender guitar but it doesn't have trem.
As to some other stuff that has been posted here:
The AVRI collet is NOT an "upgrade", on my CP anyway for sure. How do I know? I had an AVRI trem unit on my CP originally, they made it that way. I guess they were out of CP trem units at the time they built it, so they put in AVRIs. I got so frustrated with the arm just dangling there that I had the AVRI trem unit removed, and replaced with the correct CP trem unit. I perceived no diffence in function between the two on my guitar, and the Fender rep I talked to first said there shouldn't be. However with the threaded CP arm I could put a strat trem spring underneath it, hence that arm stays where I put it. Unlike the AVRI arm. To me, the CP trem is superior for that reason, and identical otherwise. No stay-trem needed , for a CP owner.
I agree that the CPs and the vintage spec guitars are essentially different guitars in many respects, but in similar looking bodies and switching schemes. That does not mean that the features of the CP that a particular vintage-spec afficionado doesn't prefer are "issues" . They may be issues for him. Whereas other players would prefer them. For example, there are a lot more players in this world who choose tune-a-matic-equipped guitars than choose vintage-spec jazzmaster bridges, so evidently a lot of people don't find that feature to be an "issue". Jazzmaster preferrers are in the minority. And have always been, save for but a few early years, that's why these guitars failed initially. Keep that in mind. Your vaunted "deliberate design" of Leo Fender, that is so sacrosanct that it can't be changed, was a big flop.
In my case, I was looking for a 24" scale length guitar with flatter radius and bigger frets than vintage spec, that's how I wound up with my CP Jaguar. The bridge did not enter into my search, but I am happy not to have to deal with all the bridge problems vintage spec players seem to wallow in. I never even think about the bridge. And I like the way my guitar sounds and plays, as it is. I wouldn't have liked the vintage spec guitars better, at the time, because those guitars do not have the neck specs I wanted.
That does not mean my guitar was perfect out of the box, I did have a proper set-up done (hence no buzzing issues), and changed some other stuff. Many of the AVRI guys change stuff too. Seemingly most of them change the bridge, and some put on buzzstops. I didn't need to do those things. I chose to change pickups, but I didn't really play it with the original ones first. And these are not Jazzmaster pickups anyway. The tech who set up my guitar said he sees exactly the same set-up issues on AVRI guitars, by the way.
To me, if I wanted a long scale guitar with a flatter radius and bigger frets than vintage spec, I would consider a CP Jazzmaster. Otherwise I wouldn't. And if I wanted a long scale guitar with vintage spec neck, I doubt I'd wind up with any Jazzmaster. They've never floated my boat in the stores. I'd probably wind up getting a Strat. A lot more players prefer Strats to Jazzmasters, maybe some of you don't realize that. Earth to Offset forum, most players don't find the vintage spec Jazzmaster design to be "perfect", or preferred. And they never did, basically.
