Isn't this a Mustang
Naturality
Post by Naturality » Tue Jan 16, 2007 11:52 pm
This looks more like a Mustang than a Duosonic, as it has the Mustang trem tailpiece. It also has the phase switches from a Mustangwhich I don't think the Duo had
flatfiver
Re: Isn't this a Mustang
Post by flatfiver » Wed Jan 17, 2007 12:13 am
IIRC the Duo Sonic II (post-'64/'65?) had the phase switches.  As for the trem it'd depend on whether it was original equipment or not.
Neither ever had 3 pickups. ;)
Pumpkin
Post by Pumpkin » Wed Jan 17, 2007 1:01 am
Thurston just put a mustang vibrato on it and it only has a 5 way switch for the 3 pickups just like a strat has.
As for the pickgaurd,i spose he changed that too and you can see theres white paint under the pickgaurd where the phase switches would be,hence ther is no route so its a pre phase switch duosonic.
When ya look at SY guitars its always best to assume "what isn't modded" rather than what is. :)
mjet
Post by mjet » Wed Jan 17, 2007 1:30 am
I wouldn't be surprised if it isn't just a regular Mustang with a DuoSonic neck. DuoSonics from 1964 until they were discontinued had the phase switches, identical to a Mustang. I doubt he'd have added a Mustang tremolo to a DuoSonic body - that's a lot of work on a cheap guitar. Mustang, DuoSonic and Musicmaster necks are all stamped the same and are interchangeable.
Pumpkin
Post by Pumpkin » Wed Jan 17, 2007 1:45 am
Its a duo definitely.
JazzBlaster
Post by JazzBlaster » Wed Jan 17, 2007 1:51 am
you are all wrong! it is a sonic youth guitar therefore woven from high quality duct tape!
FireAarro
Post by FireAarro » Wed Jan 17, 2007 2:22 am
JazzBlaster wrote: you are all wrong! it is a sonic youth guitar therefore woven from high quality duct tape!
lo-fidelity duct tape?
mynameisjonas
Post by mynameisjonas » Wed Jan 17, 2007 3:06 am
as corona said, it has no routes for the switches. it is definitely a duo sonic.
a mustang tailpiece and its routes isn´t that hard to add. screwdriver/chisel... hammer... bang bang, chop chop, screw screw... done! ;D
fullerplast
Post by fullerplast » Wed Jan 17, 2007 4:20 am
Wait a minute... it's an offset body. That makes it a '64 or later, and ALL those bodies have the channel route for the switches above the pickups(Mustang/DuoII/MusicmasterII).
The pre-'64 Duo and MM used a NON-OFFSET body, and were routed for a toggle switch on the lower horn.
That thing is just a mutt, you can't tell what it is or was...
Q. Are we not men?
mynameisjonas
Post by mynameisjonas » Wed Jan 17, 2007 4:23 am
ooops, didn´t think about that :-[
fullerplast
Post by fullerplast » Wed Jan 17, 2007 5:14 am
Further.... it has a spaghetti logo, which was never used on the 24" neck for any model.
A mutt, to be sure...  ;D
Q. Are we not men?
Pumpkin
Post by Pumpkin » Wed Jan 17, 2007 5:58 am
I'd probably be inclined to think its a transitional parts guitar or something cause its neither a standard duo or a  mustang.
True,it's impossible to say what it is now but its a cool guitar non the less.
fullerplast
Post by fullerplast » Wed Jan 17, 2007 6:28 am
What's strange to me is that the guard was obviously custom-cut for three pickups. So why not omit the switch cutouts as well?
Maybe there are routes under there, but they're blcoked off by some shielding or something. Odd the shielding would be white, but go figure.
It could also be an aftermarket body... but again, why would the guard be cut for switches in the first place?
Q. Are we not men?
djetz
Post by djetz » Wed Jan 17, 2007 6:43 am
fullerplast wrote: What's strange to me is that the guard was obviously custom-cut for three pickups. So why not omit the switch cutouts as well?
It could be a store-bought replacement guard, with extra pickup routes cut into it, rather than a custom made one. That seems more likely to me.
I suspect it's a Duosonic with added pups and whammy, most likely scavanged from a destroyed Mustang.
-=264=-
Jay
Post by Jay » Wed Jan 17, 2007 7:03 am
It's certainly possible that the switch routes are there but just covered by something stuck to the pickguard from underneath.
