Does a Jazzmaster fit in a 60's Jaguar case?
lapsteel
Post by lapsteel » Tue Jan 09, 2007 4:21 am
Are there any differences between jaguar & jazzmaster cases from the sixties?
Soiouz
Re: Does a Jazzmaster fit in a 60's Jaguar case?
Post by Soiouz » Tue Jan 09, 2007 4:50 am
They're supposed to be the same cases, although with the Jaguar, there will be a bigger gap between the headstock and the case because of the shorter neck.   The Jazzmaster will fit real tight.
lapsteel
Post by lapsteel » Tue Jan 09, 2007 5:31 am
Post by mezcalhead » Tue Jan 09, 2007 8:42 am
There's a little wooden bar, covered in the same material that lines the inside of the case, which fits just next to the headstock and is supposed to convert the case from a Jazzmaster to a Jaguar.
However, the case I've got with one of those bars in it actually fits a Jazzmaster perfectly if you squeeze it in .. in the cases that don't have those bars, the JM has a bit of wriggle room. I assume that's because the padding in the lined has compressed down over the years where the guitar rests on it.
fullerplast
Post by fullerplast » Tue Jan 09, 2007 8:46 am
Some Jag cases have the bar that Mez mentions, but many don't. I've seen the spacer at either (or sometimes both!) ends. I don't think they were real consistent... either originally as shipped or at the store when bought.
Q. Are we not men?
Post by zhivago » Tue Jan 09, 2007 9:12 am
here is the spacer....
Post by mezcalhead » Tue Jan 09, 2007 10:43 am
I was going to offer to photograph mine .. I should've known there'd be no need for it!
That top pic is so cute. It looks as if with the proper care and feeding it should grow into a whole case.
Post by zhivago » Tue Jan 09, 2007 10:52 am
mezcalhead wrote: That top pic is so cute. It looks as if with the proper care and feeding it should grow into a whole case.
hehehehehee!!
that made me laugh out loud! :D
mjet
Post by mjet » Tue Jan 09, 2007 10:54 am
:P
mewithoutus
Post by mewithoutus » Wed Jan 17, 2007 4:22 am
um, does anyone know where i can get a case for my jagmaster, and not spend an arm and a leg for a fender one? those fender jaguar/jazzmaster cases are freaking expensive.
=--->christopher
myspace.com/foxestheband
Gustav
Post by Gustav » Wed Jan 17, 2007 8:46 am
mewithoutus wrote: um, does anyone know where i can get a case for my jagmaster, and not spend an arm and a leg for a fender one? those fender jaguar/jazzmaster cases are freaking expensive.
I have a case for my Jaguar that have a badge that says "Rockcase by Warwick". It were much cheaper than a Fender case.
Here's a link: http://www.banzaieffects.com/RockCase-D ... 13376.html
And a link to the cheaper "not deluxe" model  :) : http://www.banzaieffects.com/RockCase-J ... 13326.html
mewithoutus
Post by mewithoutus » Wed Jan 17, 2007 4:15 pm
oh right on thanks alot. do they sell these in the us from a us retailer?
=--->christopher
flatfiver
Post by flatfiver » Wed Jan 17, 2007 9:04 pm
mewithoutus wrote: oh right on thanks alot. do they sell these in the us from a us retailer?
The U.S. distributor for Warwick/RockCase is Dana B. Goods - http://www.danabgoods.com/ - I'm sure they could get you a list of retailers if you called or e-mailed them.
aen
Post by aen » Fri Jan 19, 2007 8:40 pm
A jazzmaster will definetly fit in a soft Coffin Case.
And you can leave it in your car unlocked, because anybody scummy enough to steal the BC rich they think is in that case already has one.
I prefer their older stuff.
dltinter
Post by dltinter » Mon Jan 22, 2007 5:08 pm
Same case for both.
