Re: Jazzmaster neck and bridge pu's... the same?
daydreamdelay
Post by daydreamdelay » Thu Dec 07, 2006 6:21 am
someone's parting out a '66 JM on ebay and I'm watching the pickups.. I want to replace the AVRI bridge pu in my '66 and asked which of the two auctions was for the bridge pu and was told they're both the same. Is this really true?  I always assumed they were a bit different  ???
mynameisjonas
Post by mynameisjonas » Thu Dec 07, 2006 6:32 am
yeah, the neck pickup should be RWRP.  maybe the seller is unaware of this and just assumed they were the same  ???
Post by zhivago » Thu Dec 07, 2006 6:33 am
I'd think that the neck pup would be hotter than the bridge pup....which is normal on guitars....
can he give you readings of the pups?
daydreamdelay
Post by daydreamdelay » Thu Dec 07, 2006 6:36 am
yeah it doesn't sound right.. I've never heard of them being the same before, it'd be nice to know which is which. I assume they came out with the same reading since he says they're the same but I'll ask him
Soiouz
Post by Soiouz » Thu Dec 07, 2006 6:42 am
Would the length of the ground wire be any indication at all?    I would assume the longer wire is for the bridge pu, but I might be wrong. ???
daydreamdelay
Post by daydreamdelay » Thu Dec 07, 2006 6:46 am
probably not by enough to make it a given
Naturality
Post by Naturality » Fri Dec 08, 2006 8:24 am
They are the same pickups, but they need to be setup differently to create the different sounds, it's the same with all guitars with two of the same pickup , like all Gobsons's  :-\. The bridge pickup is lower down to give a mellower sound.
mynameisjonas
Post by mynameisjonas » Fri Dec 08, 2006 9:00 am
zhivago wrote: I'd think that the neck pup would be hotter than the bridge pup....which is normal on guitars....
isn´t it normally the other way around? ??? slightly hotter bridge pickup to compensate for the smaller vibrations close to the bridge..?
anyway, i´ve always been under the impression that vintage jazzmaster pickups were wound to the exact same output, but with the neck RWRP.
DB
Post by DB » Fri Dec 08, 2006 11:13 am
OK, dumb question:
I know what RWRP means, but WHY would you need one that way?  With singles I assume you could reduce hum, but with HBs would it matter? I'm showing my electronic ignorance here, and any clarification would be appreciated.
DB
IV, V, VI, XII...
Orang Goreng
Post by Orang Goreng » Fri Dec 08, 2006 11:23 am
DB wrote: With singles I assume you could reduce hum, but with HBs would it matter?
Jazzmaster pickups are single-coils.
aen
Post by aen » Fri Dec 08, 2006 12:55 pm
I htink that was referring to the earlier gibson comment.
Soooo, what im gleaning form this conversation is that if i swapped my old CIJ jazzmaster neck pickup out into the bridge position, it would sound quite the same?
I prefer their older stuff.
Orang Goreng
Post by Orang Goreng » Fri Dec 08, 2006 2:10 pm
Oh shit. Sorry.
daydreamdelay
Post by daydreamdelay » Fri Dec 08, 2006 2:20 pm
so are they the exact same or is one RWRP?
sellers says they're exactly the same, I doubt I'll be able to bid but incase something comes up and I can or I see another non specified '66 pu it'd be nice to know for sure if they're the same or not.
oh and.. how can you tell the difference?
DB
Post by DB » Fri Dec 08, 2006 2:48 pm
aen wrote: I htink that was referring to the earlier gibson comment.
I was, but I also learned the JM pickups are single.  I have a Jag and Bass VIs and didn't know.  I got my question answered *and* learned something new.
DB
IV, V, VI, XII...
mynameisjonas
Post by mynameisjonas » Fri Dec 08, 2006 4:28 pm
daydreamdelay wrote: oh and.. how can you tell the difference?
by looking at the coils and see if the wire is wound in the same or opposite direction, i guess. i don´t know how to tell which one is neck and which one is bridge though. we need doug or jim for this one i think...
aen wrote: Soooo, what im gleaning form this conversation is that if i swapped my old CIJ jazzmaster neck pickup out into the bridge position, it would sound quite the same?
the CIJ pickups are identical apart from that the neck is RWRP. if you switched places of them it would sound exactly the same.
