Schecter Offset (AR Series)
- cheese129
Hi!
I came across this guitar when searching the internet the other day, and i wanted to share it with you guys, since there is not a lot of info about it in other forums. I have always liked Schecters more traditional range of guitars, and got stunned to find out they made a offset. Ashame they only sell it in japan (there is one on reverb though). It comes with H/S (6 string) or S/S (7 string) configuration and 5 different colours. It could be a really sick mod platform (or just use it as it is.)
Here is the 7 string version:
Links:
https://www.schecter.co.jp/schecterjapan/others/ar.html
https://reverb.com/item/17100249-schect ... e-shipping
Btw: Schecter also made a Mustang clone!
https://reverb.com/item/9244746-schecte ... sonic-blue
Links:
- Stephen_42
Re: Schecter Offset (AR Series)
Wow!
They're insanely cool and not unreasobably priced, either by the looks of it. The 7 string especially looks awesome.
A bit of sleuthing around the artist models turned up this (same idea, but with Strat pickups / trem):
https://www.schecter.co.jp/schecterjapa ... k_sig.html
- leokula
- rumfoord
- Stephen_42
Some of their pickups are described as 'Twin Brade' ... blade ? ... HB in SC size ? Which is consistent with the coil split switching ...
https://www.schecter.co.jp/schecterjapa ... 07_bk.html
- windmill
That looks so much like a Jag Special that if I saw I would probably buy it !Stephen_42 wrote: ↑Wed Jan 02, 2019 1:04 pmI guess the toggle must be a kill switch or something, assuming that the wiring is otherwise similar on them all?
Yeah, that 7-string Jag Special is pretty much the Offset I never knew I needed. Pretty damn cool.
