WD40 is a water dispersant (hence the name), and an awful lubricant. I'd advise against any oil as adding lubricants at this point will make the fastener more difficult to grab hold of, particularly if the hex end has been marred or otherwise damaged.ThemBones75 wrote: ↑Tue Dec 25, 2018 4:11 pmGuys SO sorry for the late replies
I am going to see if I can find a place here.
Mastery answered my emails the night I sent them and if I need to I can send it to them.
This is a GREAT RTFM learning experience.
Thank you to everyone for responses, over the next few days I should have some time to actually take some action
WD40 or actual machine like 3 in 1 oil?
and heat do I just hold it with some pliers and apply the soldering iron for 30 or so seconds?
Immerse in pot of boiling water or a soldering iron applied directly to the fastener for a more localised heat. If the hex key won't shift it, grab the exposed end with vice grips/pliers and turn it out from the other side like I said in my previous reply.
