NGD: Road Worn Jazzmaster (+ aluminum guard page 3)
fisonic
Re: NGD: Road Worn Jazzmaster (+ aluminum guard page 3)
Post by fisonic » Sat Jun 23, 2018 3:56 pm
A dyna bolt & a soldering iron will do it. You can pack out the dyna with paper, which also helps not to marr the thimbles.
solfege
Post by solfege » Sat Jun 23, 2018 4:11 pm
Is that buckling just a matter of the screw holes being slightly off or it pushing up too tight against the neck? Or is it bent?
wproffitt
Post by wproffitt » Sun Jun 24, 2018 6:03 am
I had the same buckling thing happen when I put my aluminum guard on my CP JM. It’s so minor on mine (though I can see it when I’m looking down at the guitar) that I’ve decided I don’t care enough to do anything about it. :) In my case, I’m 100% sure that it had to do with the screw holes not being perfectly aligned.
edwardskim
Post by edwardskim » Sun Jun 24, 2018 7:59 am
That guard looks really nice. I think it only works with a worn/non-gloss finish body. And this is great!
invisible man
Post by invisible man » Sun Jun 24, 2018 8:25 am
Oooo, yes I should have thought of that! Thanks
https://soundcloud.com/billy-gashade
invisible man
Post by invisible man » Sun Jun 24, 2018 8:28 am
Yeah I think the guard's screw hole in that spot is ever so slightly off, and there's not much I can do about it. It's pretty minor, only noticeable from that angle, I think I will just live with it.
invisible man
Post by invisible man » Mon Jan 21, 2019 9:13 pm
Mastery bridge, Staytrem collet and arm (bought used), US locking trem, D’Addario 11-52s installed, SKB case. Ready to go finally! If only I could say the same for my amps...
