Help With A Wiring Questions
- Kinggoat
Hello guys. I bought a wiring harness for my J. Mascis Jazzmaster. It is wired up so that the 2 roller knobs are tone controls one for each pickup. The 2 main pots are individual volume pots. The slider is a kill switch. The 3 way toggle works as normal. My question is where do I attach the pick up wires? The 2nd question is how do I turn that slider switch from a kill switch to a series, parallel, and normal switch? That one will be a future wiring project. Right now I mostly want to get the pickups soldered in. Thank you for your help.
Re: Help With A Wiring Questions
Which harness did you buy ? It should come with a wiring diagram. Or online at vendor's site.
- MechaBulletBill
I'm guessing it's wired like a Gibson (2 vol, 2 tone) so you probably need to connect the pickups to the volume pots
- Kinggoat
I bought one of the 920D custom wiring harnesses. I don't see a diagram on their web page and it didn't come with a diagram.
It's kind of hidden on the page for the 2V2T harness ...
https://920dcustom.com/products/fender- ... ill-switch
Scroll through images and you eventually get to this ...
