Yamaha SG-3 bridge saddle issue
Ironheart
Post by Ironheart » Sat Jul 09, 2016 7:16 pm
I bought my Yamaha SG-3 a couple months ago and I still haven't been able to find a replacement saddle adjustment screw for the low E String. It's a slotted head style and its about half the size of a more modern Hex head saddle screw.
Anyone have a resource in finding a vintage or NOS replacement? Any specific measurements to find an exact replacement? I don't care if I have to replacement all, for them all to be the same. I just want it to be complete.
Any info/help would be great.
Thanks
Daniel
cbrown
Re: Yamaha SG-3 bridge saddle issue
Post by cbrown » Sat Jul 09, 2016 10:56 pm
Since it's Japanese, it's most likely to be metric. A standard Strat saddle height screw is 4-40 UNC thread which has an external diameter of 0.112" or ~2.85mm. The Yamaha screw is a wee bit smaller so will probably be an M2.5 thread.
These are probably perfect for you http://m.ebay.ie/itm/M1-6-M2-M2-5-M3-A2 ... 0179951717" onclick="window.open(this.href);return false;
frelonvert
Post by frelonvert » Sun Jul 10, 2016 1:09 am
I believe Cbrown option is the best solution.
For my SG-2, I had a missing bridge saddle screw and I made one with a TOM saddle screw, cuting the top and making the "place" for the screw driver (don't know how to name it in english).
MattK
Post by MattK » Sun Jul 10, 2016 3:20 am
If you have a Dremel or similar tool, all you need to do is buy a stainless screw of the right metric diameter, machine or metal screw, with a flat tip not a point - take the saddle to the hardware store to (carefully) test if the thread fits. Then use the Dremel to cut a slot in the tip, to the right depth, and then cut the screw off at the right length.
Sonichris
Post by Sonichris » Tue Jul 12, 2016 5:06 am
^^that's what I've done too. Many many times. Those screws are always missing it seems.
Artslap
Post by Artslap » Fri Jul 15, 2016 5:53 pm
Did you sort this out Ironheart?
I recently made one.
I'd be happy to do another if you are still in need.
CP.
"Curiosity killed the Cat. He's buried alongside all the great minds we never had." - P. Dempsy - SFK
Ironheart
Post by Ironheart » Tue Aug 09, 2016 2:00 pm
Artslap wrote:Did you sort this out Ironheart?
CP.
Hey Artslap. I actually just ordered a set of adjustment screws yesterday. Thank you very much though. Appreciate the help/consideration from you and everyone.
