carefully stripping vintage refins
- øøøøøøø
Considering sending my old strat to Danocaster for a refin.
Neck and body have been refinned already, repro decal.
I wonder whether pencil markings might be somewhere under there on the body, and on the neck I KNOW they're on the butt end. I want to save that.
To tell the truth, I'm a little scared to go stripping a guitar. I want to avoid doing harm most of all. Dan doesn't have time to strip guitars right now. I'm not sure I want to undertake this right now; I might have to build up some courage.
I'm seeking the advice of restorers here... I can see a few possible ways forward.
1) use acetone or lacquer thinner and very slowly, painstakingly remove the existing lacquer
2) use a gentle stripper like Citristrip and just try to avoid the areas I want to protect
3) something else, add your own.
Any thoughts?
Any thoughts?
- Telliot
Re: carefully stripping vintage refins
There are people here who are much more qualified on this subject than me, but I would do a gentle stripper and let it do its thing. Nitro should come off fairly easily, but you definitely may have a harder time with poly and need to be patient, doing several passes. Any pencil marks or stamps underneath should be safe unless you start sanding in that area. Out of curiosity, why do you want to refin the neck?
- øøøøøøø
I don't like the feel of the later lacquer that's on there (doesn't feel 'right' like a 50s or 60s Fender), the headstock decal is a repro and I might be able to get a better repro, and it needs a refret anyway.Telliot wrote:Out of curiosity, why do you want to refin the neck?
- Ursa Minor
Not sure if it's whats your asking, but Citristrip won't erase pencil marks. I've uncovered a few on refin'd bodies in the past just by isolating the specific areas.
It will eat right through any nitro in a hurry. I doubt you could use Citristrip to uncover layer by layer - maybe if you dilute it. I would wet sand in that case - especially if you have potential original finish underneath.
- øøøøøøø
I'm pretty positive at this point that there's no original finish underneath, contrary to what I was told when I bought it, so it's really potential pencil marks I'd want to uncover and protect.
- Ursa Minor
This was done with Citristrip. Pretty thick old spray can black removed. Didn't touch the pencil mark at all.
I just scraped the mushy old paint away with a credit card.
- mgeek
Stop mincing around and strip the finish the way our forefathers back in the 70s would have done it: 60 grit paper epoxied to a nice round stone.
- PorkyPrimeCut
Epoxied to a nice round stone? Tsshh!! You were lucky!!mgeek wrote:Stop mincing around and strip the finish the way our forefathers back in the 70s would have done it: 60 grit paper epoxied to a nice round stone.
My forefathers had to nail a piece of 10 grit paper to their tongues & lick t'finish off.
- MattK
Ah used t'ave to roll m'self in epoxy - original mind you, none of this five minute stuff - and roll m'self down in t'sand at t'beach. Then our da would throw t'Jazzmaster at us. IF WE WERE LOOCKY.
- mothershipzeta
Beach! Luxury! There were a hundr'd and fifty of us, living inside a can of epoxy, in the middle of the road!
indulj már, hé / embermlék / önmagától gyulladó fény!
- jmac
I like this thread.
- Bothand Nether
Please, more of these master tips & tricks.
What type of stone should I be using for my 60 grit sanding stone?
The granite here is not useable, it is crumbly and smells like clumped kittylitter.
Oh, wait.
Oh, wait.
"No short-haired, yellow-bellied Son of tricky dicky's Gonna mother hubbard soft soap me"
-The late Mr. L.
-The late Mr. L.
- howdo3313
I'm in a similar spot currently. Looking to raise the date in the pickup route without affecting the pencil lead.
Citristrip and Nirtomors(UK) aren't available in Canada though.
And I am unsure about what's available up here that will do the trick.
What a doodle doo, in a town full of heroes and villains
- Bad Monkey
you had a whole can? jeeez, we thought we had it made when we got the lid.mothershipzeta wrote:Beach! Luxury! There were a hundr'd and fifty of us, living inside a can of epoxy, in the middle of the road!
- StevenO
Not sure if EZ Strip affects pencil marks, but it does a good job at removing paint!howdo3313 wrote:I'm in a similar spot currently. Looking to raise the date in the pickup route without affecting the pencil lead.
